Thread: coolant warning
    Regular Member m1ke823146's Avatar
    Aug 2009
    derby
    Default coolant warning
    hi guys can anybody tell me if im worrying about nothing? twice now iv had the coolant warning pop up (picture of radiator) both times after just starting the car, one i took a left corner fast and the other i reversed and braked. after the first ocassion i checked (when cold) the header tank level and it was low (1 cm below cold mark) and i topped it up, the second time (2 weeks later) i checked the level and it was at the cold mark while the engine was warmed upto running temperature, any ideas? ive owned the car about a year and it hasnt done it before when taking corners fast and braking, there are no visible signs of a leak or crystalisation, no bubbling in header tank and no mayo in the oil.
    as there is no visible sensor in the header tank i assume it is on the radiator? if so on both occassion ive had an x amout of coolant in the header tank when hot and cold so therefore a sensor on the radiator should not be tripped??? if i should check the wiring to the coolant level sensor where is it and how do i get to it ( 52 vectra c 2.0dti) although if the level is at the cold mark when warm, surely if lost some coolant??
    any ideas anyone????
    many thanks
    mike
    Oct 2009
    rhyl
    hi mate mine needs topping up every so often mines a 2.0t and my dads needs topping up every sooften the sensors are so sensitive that if its a few mm under that light will come on then you might turn ignition off then it won't come on again check you r water level
    I had this a few times last week, found the coolant was correctly at the "KALT" mark, so checked the gravity of the coolant and found it was too low
    I bought one litre of VX Coolant
    I drained the header of about 600ml, and refilled to the "KALT" mark
    I then ran the engine for a short trip, then rechecked the gravity and was more acceptable
    So much for the VX dealership checking the gravity at last service!
    Aug 2009
    derby
    as per above, i have topped it up (vx orange) the coolant for the second time now, i estimate (when cold) that over two weeks the level drops 1 to 2 cm, what concerns me is that i didnt have to do this untill after over a year of ownership. it may be woth noting that i had a new thermostat and new coolant fitted by vx 2 months ago as the old one was slow, i have checked for leaks around it but there are none, will check the gravity asap, any other ideas ?
    thanks for advice
    mike
    Wales, UK
    Whats gravity ? lol
    Aug 2009
    derby
    Quote Originally Posted by mark_647 View Post
    Whats gravity ? lol
    the strength of the coolant
    Whats gravity?
    It's the concentration of the coolant to water
    The dropper is available from most good motor accessory shops
    Its called gravity as the indicators slowly fall when the concentration is very low
    Mine came up as -14'C
  1. coolant warning light
    By LarfinBoy in forum Engine & Drivetrain
    Last Post: 9th June 2011, 10:18
  2. V6 Coolant Warning Light
    By iani in forum Engine & Drivetrain
    Last Post: 30th May 2011, 14:12
  3. Coolant warning light
    By sproket in forum Troubleshooting
    Last Post: 17th May 2010, 19:15
  4. Low coolant warning light -3.2 GSI
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2009, 09:33
  5. Coolant Warning Light
    By parapaul in forum Engine & Drivetrain
    Last Post: 4th October 2008, 18:25
