Thread: Thermostat misery!
    Regular Member K18 JRT's Avatar
    Oct 2006
    exeter
    Default Thermostat misery!
    Any advice guys, I replaced thermostat/housing 2.0Dti all went well apart from top bolt doesn't want to tighten up at all and obviously it is leaking.
    So from what i can gather the threads are stripped and don't really have a clue how to get out of this mess.
    I knew i should have left it alone but i thought i couldn't go wrong with that as it seemed so simple.
    Sep 2009
    Scotland
    Is there is resistance at all on the bolt or is it just spinning freely? you may need to get a helicoil insert or similar fitted.
    They may be other options (not including taking it apart and using rtv sealant as well as the gasket )
    Oct 2006
    exeter
    Slight resistance but just goes round and round and doesn't actually pinch up if you see what i mean.
    I'm pretty sure i never over tightened it to strip it but i guess i must have!
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Is this on a flange or a blind hole? If a flange put a longer slightly smaller bolt right thro' and a nut on the back. Or, try a slighty longer bolt and try to pick up enough thread that way. Or, as bogjoe last resort a helicoil tap and coil.
  1. Anti-roll bar bushes misery
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 14:48
  2. Anger. Misery. Shame.
    By RobW in forum General Chat
    Last Post: 2nd October 2010, 00:27
  3. 2.2 direct clutch misery
    By idobigmls in forum Engine & Drivetrain
    Last Post: 2nd September 2009, 00:31
  4. Shall we put him out of his misery....
    By BigMan in forum General Chat
    Last Post: 11th January 2008, 12:27
  5. 2.2 dti turbo misery!!
    By regishaunus in forum Engine & Drivetrain
    Last Post: 31st March 2007, 22:24
