Results 1 to 10 of 16
Thread: Uneven tyre wear
    Default Uneven tyre wear
    My car has started to exhibit uneven tyre wear
    I noticed it on the last tyre change, with the nearside had worn slightly more than the offside (but it was only about 1mm)
    However, it has accelerated such that the nearside is down to the legal minimum and the offside still has 4mm on it
    Equally, the nearside has worn out in just 4500 miles since the last tyre change, the offside has the normal amount remaining (typically 7000 to 8000 miles)
    This suggests either :
    the nearside rear suspension is at fault
    or
    the nearside front suspension is at fault
    However, this was inspected yesterday and no problems could be found
    The tyre fitter agreed that the nearside front was clearly showing signs of unusual wear, knowing that I fit new tyres to the rear and swap to the front as they wear, "We weren't expecting to see you for another set of tyres until mid-March"
    The tracking was then checked, but also found to be correct
    Therefore, does anyone have a copy of the CORRECT tracking angles for :
    2004MY 3.0 V6 CDTI SRI, sports suspension, 17" wheels
    I've now phoned three (different) VX dealerships and they refuse to release the details
    Full Member Big Sig's Avatar
    It could also be the tyre itself.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Front wheel adjustment
    Saloon
    Saloon with "Sport" equipment
    Saloon with "Bad Road Surface" equipment
    Difference right/left maximum
    Camber
    -1° 02' ±45'
    -1° 05' ±45'
    -0° 55' ±45'
    Caster
    2° 54' ±45'
    3° 08' ±45'
    2° 54' ±45'
    Toe-in1)
    0° 00' ±10'
    Toe-in variation with inner wheel deflection of 20°
    1° 38' ±45'
    Outer wheel deflection for 20° inner wheel deflection
    18° 22' ±45'
    Rear wheel adjustment
    in accordance with trim height2)
    Saloon
    330 - 334
    Camber
    -2° 36' ±15'
    Toe-in1)
    +0° 28' 30" ±10'
    335 - 339
    Camber
    -2° 29' ±15'
    Toe-in1)
    +0° 25'30" ±10'
    340 - 344
    Camber
    -2° 21' ±15'
    Toe-in1)
    +0° 22' ±10'
    345 - 349
    Camber
    -2°14' ±15'
    Toe-in1)
    +0° 19' ±10'
    350 - 354
    Camber
    -2° 07' ±15'
    -2° 07' ±15'
    Toe-in1)
    +0° 31' 30" ±10'
    +0° 15' 30" ±10'
    355 - 359
    Camber
    -2° 00' ±15'
    -2° 00' ±15'
    -2° 00' ±15'
    Toe-in1)
    +0°28' ±10'
    +0° 10' ±12'
    +0° 28' ±10'
    360 - 364
    Camber
    -1° 53' ±15'
    -1° 53' ±15'
    -1° 53' ±15'
    Toe-in1)
    +0°24' ±10'
    +0° 08' ±10'
    +0° 24' ±10'
    365 - 369
    Camber
    -1° 46' ±15'
    -1° 46' ±15'
    -1° 46' ±15'
    Toe-in1)
    +0° 20' 30" ±10'
    +0° 04' 30" ±10'
    +0° 20' 30" ±10'
    370 - 374
    Camber
    -1° 39' ±15'
    -1° 39' ±15'
    -1° 39' ±15'
    Toe-in1)
    +0° 16' 30" ±10'
    +0° 00' 30" ±10'
    +0° 16' 30" ±10'
    375 - 379
    Camber
    -1° 32' ±15'
    -1° 32' ±15'
    Toe-in1)
    +0° 12' 30" ±10'
    +0° 12' 30" ±10'
    380 - 384
    Camber
    -1° 24' ±15'
    -1° 24' ±15'
    Toe-in1)
    +0° 08' 30" ±10'
    +0° 08' 30" ±10'
    385 - 389
    Camber
    -1° 17' ±15'
    -1° 17' ±15'
    Toe-in1)
    +0° 04' 30" ±10'
    +0° 04' 30" ±10'
    390 - 394
    Camber
    -1° 10' ±15'
    -1° 10' ±15'
    Toe-in1)
    +0° 00' ±10'
    +0° 00' ±10'
    395 - 399
    Camber
    -1° 03' ±15'
    Toe-in1)
    -0° 04' ±10'
    400 - 404
    Camber
    -0° 56' ±15'
    Toe-in1)
    -0° 08' 30" ±10'
    405 - 409
    Camber
    Toe-in1)
    410 - 414
    Camber
    Toe-in1)
    1) Positive values = toe-in, negative values = toe-out
    2) difference between right and left max. 1 mm
    Foreword to Chassis Alignment Values for Model Year 2004
    This "Chassis Alignment Values" brochure for Opel/Vauxhall vehicles has been specially created for use on the chassis alignment unit and contains all important information which is required for the correct performance of chassis alignment.
    This brochure contains the chassis alignment values for the following Opel/Vauxhall vehicles for Model Year 2004:
    Agila, Corsa-C, Combo-C, Speedster/VX 220, Astra-G, Astra-G Coupe, Astra-G Convertible, Astra OPC, Astra CNG, Zafira, Zafira OPC, Zafira CNG, Vectra-C, Vectra-C Estate, Signum, Frontera-B, Movano and Vivaro.
    Important: There are several adjustment values for the rear axle of the Vectra-C, Vectra-C Estate and Signum which refer to different vehicle trim heights. The trim height stated here is measured from the centre of the wheel hub to the lower edge of the wheel arch on each side of the vehicle. In addition, the vehicle is to be levelled horizontally by distributing weights in the rear area of the higher vehicle side.
    In order to visually emphasize new values and values that have changed since the previous brochure, the values in these data fields are shown in bold with a grey background and the boxes around them are drawn in dotted lines. For information with differing tolerance values the visual emphasis can only be provided for the main information, but the tolerance may be affected by the change anyway, as shown in the following examples:
    Display of new or modified values with same +/- tolerance:
    Display of new or modified values with different +/- tolerance:
    1° 45' ± 45'
    0° 00' +30' / -45'
    Note: A special adapter is required for vehicles with new lightweight alloy wheels to attach the wheel mirror or measuring unit for chassis alignment.
    We had a good look at the tyre, the balancing and pressures on all four were perfect
    There is no sign of adverse "abnormal" wear, as a result of failed suspension
    This tyre does tend to wear slightly on either the inside or outside edge, but overall the wear rate is normally the same as the offside
    There is clearly something wrong as this is the second tyre in a row on the nearside front that has worn before the offside front, but this time it is worse
    Regular Member wardy's Avatar
    Chichester
    my 3.0 did this. It turned out to be down to the tyres Goodyear F1s being non-XL rated. Switched over to Falken 912 XLs and never had a problem again
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    unless a bump has put the rear out a litttle. upper rear arm play
    Didn't realise it was the secone one in a row, I was wondering if it was a batch fault with the compound being softer for some reason.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    No one's suggested that the camber angles might be out? http://www.wheels-inmotion.co.uk/tech-camberbasics.php
    Quote Originally Posted by wardy View Post
    Apart from some tyre testing between July and November 2008, the car has always been on XL rated tyres, also with the correct tyre pressures (even though VX keep putting them back to the tyre pressures for a 1.9 CDTI at each service!)
    The car has been on Good Year F1 225/45 R17 94Y XL since April 2009
    08 Apr 2009 - 77626 miles
    07 Jul 2009 - 84519 miles
    26 Sep 2009 - 92955 miles
    16 Dec 2009 - 99680 miles (nearside tyre showing uneven tyre wear)
    Feb 2010 - 104000 miles (nearside worn to legal minimum)
    Quote Originally Posted by mattv6diesel View Post
    The suspension was fully checked, no worn or damage parts could be found
  1. Uneven tyre wear part 2
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2011, 11:53
  2. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  3. Uneven Tyre Wear
    By sri/cdti/150 in forum Handling & Braking
    Last Post: 19th February 2011, 11:33
  4. REALLY uneven tyre wear
    Last Post: 21st November 2010, 23:25
  5. Uneven Tyre wear
    By Manni2375 in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2007, 15:19
