Thread: vxr astra and vectra vxr gearbox are they same?
    halifax
    Default vxr astra and vectra vxr gearbox are they same?
    is the vectra 2.0t gearbox same as astra 2.0t vxr?#
    what transmission fluid do you use in vectra 2.0t gearbox?
    what transmission fluid do you use in astra vxr 2.0t gearbox?
    please only post if you know for 100% and if i can use non vauxhall and the grades. ta
    Oct 2009
    rhyl
    the engines are tottaly different so not sure about gearbox vauxhall should know this
    Regular Member wardy's Avatar
    Chichester
    The vectra vxr isn't a 2.0T its a V6 2.8T
    Regular Member VXR_DV's Avatar
    South Coast
    Not the same gearbox.
    Astra uses an M32 gearbox.
    Vectra uses F40 gearbox.
    No idea about the Vectra Auto.
    dv.
    Regular Member evyboy's Avatar
    Jul 2009
    hamilton
    Think the best place too ask this question is a dedicated VXR site like the one i use they will be able too advise the best upgrade oil too use
    The astra vxr uses the M34 gearbox
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    The Vectra uses the M32 box as well I'm just unsure if its the same housing and ratios etc as the Astra VXR, but the M32 is used on the CDTI's and the VXR afaik.
    Jun 2006
    Northampton
    Quote Originally Posted by evyboy View Post
    M34? don't think I've heard of this, I know its not listed on EPC.
    South Coast
    Quote Originally Posted by danBoy View Post
    Vectra VXR uses F40.
    Jul 2009
    hamilton
    Was a typo, sorry,
    Vec vxr uses m40
    Astra vxr uses m32
    Vec 2.0t uses m32 but they have differant final drives and ratios iirc
    Leicester
    Vectra 2.0T uses the F40 gearbox.
    A popular modification (if a little expensive to do) is fitting the final drive from the 2.0T F40 into the 2.8T F40.
    It gives the same effect on acceleration as adding about another 30bhp. Sparky VXR has his Vectra F40 modified with the 2.0T final drive and when in standard form (255) it easily out sprinted a standard 280 VXR!
    In answer to the initial post, why change the fluid, just leave it as it is.
    Vectra and Astra both use M32, Vectra mainly uses the F40 though.
  1. Astra CDTi 150's.... different gearbox..??
    By Dan_BlackSRi in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2010, 19:36
  2. Gearbox compatibilty for Astra Mk5 !?
    By djhallam in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 19:48
  3. Vectra Gearbox
    By kjiveson in forum Engine & Drivetrain
    Last Post: 12th August 2007, 15:00
vectra vxr gearbox
vauxhall vectra vxr gearbox
