Thread: Sat Nav stuck in Germany
    Berks
    Cool Sat Nav stuck in Germany
    Newbie here, recently acquired a Vectra 2.2 SRI on an 05 plate and mightily impressed with it, only thing is..
    The built in Sat Nav 'position' map always seems to be stuck in germany - and my location on the map moves around germany - even though im driving around the home counties of england! so its telling me i am in germany, or last time i looked it told me i was driving near Prague, even though i was actually in west london!
    Anyone shed any light on this? do i need to reset something or upgrade a nav cd?
    Take the disc out - probably a german one or the last owner went on holiday there and left the disc in...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Or satnav arial having problem.. when got mine it clamied that i was in the north sea.....
    Berks
    Thanks guys, well i double checked and I've got correct CD70 UK disc in there and even tried the European disc but still the sat nav position map told me i was in germany..
    Any ideas where the sat nav antenna is located?
    Dunstable
    The gps antenna is located in the aeiral base on the roof, and plugs directly into the headunit in the back
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    its in your the base of your antennae on the roof, unless the CD70 was an upgrade then it could well be a fakra unit in the dash behind the CD70 headunit..
    Berks
    the antenna looks pretty well fixed externally, would i need to remove interior ceiling panel to check the connections on it?
    Kenp - how did you fix your sat nav to get it back from showin the North Sea location?
    Engine : 2.2 Direct
    checked the wires on the back of the stereo.. and it was partial out.
    Regular Member Matty777's Avatar
    Jan 2010
    Nr Maidstone
    Perhaps your "Route Preference" has "[X]via Bierfests" highlighted???
    Sorry......
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If the aerial is at fault, then you can get a relatively cheap one ( £10 to £15) off ebay.
    Just need to ensure that you look for a GPS aerial with a Fakra plug on it.
    VW's and Audi listed aerials will also work on the CD70. - Plugs onto blue plug at the rear of the radio...the white plug is for the two radio receivers...(radio and TMC traffic)
  1. Hello from Germany
    By Jojo81 in forum Introduce yourself.
    Last Post: 7th March 2011, 15:28
  2. Hi from germany
    By Freiburger36 in forum Introduce yourself.
    Last Post: 24th January 2011, 09:59
  3. Hello from Germany
    By connectab in forum Introduce yourself.
    Last Post: 13th January 2011, 17:37
  4. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  5. Everyone going to Germany
    By Madgunner in forum Irmscher Factory Road Trip - 13-16th April
    Last Post: 12th April 2007, 17:42
