Results 1 to 10 of 18
Thread: Cruise control
    Regular Member muzmayhem's Avatar
    Jan 2010
    North Angus, Scotland
    confused Cruise control
    Just bought a 2.2 DTi signum last week and just noticed that the cruise control does not work. No lights on dash, nothing. Any ideas folks?
    Regular Member signum03's Avatar
    worthing
    are you sure you model has it?
    Mar 2007
    North East
    Thought all Signums had cruise ??
    Could be a dodgy spring on the clutch, try holding the clutch pedal up with your foot and engage cruise.
    Regular Member IrishWhiskeyChaser's Avatar
    Jan 2010
    Ireland
    Yea .. the slightest pressure on the clutch and it knocks it off so if the spring is gone or strained on the clutch it may just be permanently knocking it off.
    I can't even touch my clutch pedal with out knocking it off
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    cruise control??...had my 2T for 2 years and never knew i had it,or do i? And if i do how do i make it work????
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Quote Originally Posted by nikroc View Post
    If you do have it it'll be a switch at the end of your indicator stalk, press it at the top for speed up and bottom for speed down.
    Jan 2010
    Thanks. I'll give it a shot on my way to work tomorrow.
    Oct 2009
    rhyl
    my dads was the clutch switch he had nothing no cruise control light coming on nothing and mine plays up sometimes
    Nov 2007
    DERBY
    16 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks Danialj32...i do have the cruise switch,just checked
    How does it work?...IE whats the process of actually making it work??
    Jan 2010
    Ireland
    While driving at a constant speed (with Foot off Clutch) press the top of the button with the pimple sticking out at the end of the left stalk. A green light looking like a speedo and a small arrow pointing at 10 o Clock roughly will come on you dash. Cruise control is supposed to activate then.
    You can then hit the top bit again to speed up or the bottom bit (hollow bit) to slow down. There is a narrow button behind this to turn off or you can just break or tap the clutch all turn it off.
    Have fun ...
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
