Thread: What have i done? Dropped EGR gasket in engine bay...
    Regular Member OSSY's Avatar
    Apr 2009
    Default What have i done? Dropped EGR gasket in engine bay...
    Hi all,
    Being my usual self (clumsy) I've only gone and dropped my EGR gasket into the engine bay. WTF...
    I've made another from a 7Up can - Does anyone know how long it will last for? I've taken the car for a spin; it works, but for how long?
    Regular Member justyb's Avatar
    wigan
    not long m8 the cans m8 from ally
    Apr 2009
    days, weeks, months - hours?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    What one did you drop mate the one on the pipe(oval one) or the square one between the egr and inlet manifold?
    It should last long enough to get you to the stealers and back.If you undo the back screws on the undertray or the sump hatch you may get your hand in and find it.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    It only needs to last 1 day if you go and get a new one tommorrow.
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    Buy a new set - they're only a couple of quid!
    Apr 2009
    Thanks guys - lol - what a tw*t... I dropped the oval one... Not the one to the manifold... Pluss side the EGR is clean now...
    Aberdeenshire
    Haha know how you feel mate,i was canging my air filter and i dropped one of the screws so i jacked up the car removed the under tray retrived the screw put the undertray back on then carried on with the air filter.i then dropped the ****** torx driver didnt i had to do it all over again that was a bad day lol.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by OSSY View Post
    Hi all,
    Quite easy to do unfortunately, they do tend to fall off when you lift off the EGR sometimes, it happened to me, but was able to see it and recover it.
    It may be okay with the homemade one, but me personally if only for peace of mind I would probably get a replacement from the dealers, about £2 each.
    I assume yourve gotten underneath and tried to move your hand across the plastic bottom cover, I've manage to recover the odd bolt I've dropped by turning the wheels to their extreme and there's a bit of room to just get your hand up from the bottom.
    When my gasket dropped it was located in between some pipes and had not fallen right down. Another good look perhaps... obviously better if you can find it, in case it rattles around... Best of luck!
    If it had been a bolt or anything made of steel I would have suggested using one of those cheap telescopic magnet retrieval tools.. certainly saved my bacon a few times, even if you cant see the lost bolt just passing the magnet in the general area will usually cause it to leap onto the magnet.
    Mileage : 000
    Lump did the same to his. I think he was quoted about £1 or so each of the gaskets. But one part.( to which I forget) they wanted ...............................£ 120
    I seems an easy thing to do. Drop the gaskets down the engine.
  1. What else has been dropped
    Last Post: 24th June 2012, 22:04
  2. oops, dropped screwdriver in engine bay..
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 19:06
  3. Whats my engine code? Head Gasket trauma!
    By sri andy in forum Engine & Drivetrain
    Last Post: 25th April 2009, 16:06
  4. 2.7 and 2.9 V6 dropped?
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 23:21
  5. Dropped Key
    By MattW in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2008, 02:13
