Thread: Front washers
    Glasgow
    Default Front washers
    Motor sounds fine, back jets ok but nothing at the front. Managed to pump air through and eventually forced air back to the filler. How can I get in to clean the bottle out ?
    Nic
    Nottinghamshire
    Quote Originally Posted by Nicolas View Post
    Nic
    Turn steering full lock right then undo the 3 torx screws at the front of the front nearside wheelarch. Pull the wheelarch liner out and you can see the washer bottle and pump. Check the 2 pipes are still attached to the pump as it may just be the pipe for the front washers has come off because the back one is still OK. Someone also mentioned checking the seals in the right-angle pieces on the end of the pipes that push on to the ump haven't got dislodged and blocked up the pipes.
    If that's OK then pop the pump up out of the bottle and check the washer/filter it sits in - it's probably full of gunk. This affects the front washers more than the rear as there's 4 nozzles rather than just 1.
    Clean all of the gunk off the filter and also flush the bottle out (some people use steradent) before refitting everything before refilling the bottle and retesting.
    If neither of these work then the pipe for the front washers may have come off or got kinked or blocked.
    Glasgow
    Excellent, many thanks.
    Nottinghamshire
    Let us know how you get on - what you find will come in useful for anyone else who has the same problem.
    Glasgow
    Will do....thanks again.
    tyne and wear
    anyluck with them washer jets mate?
  1. front washers
    By coooky in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2012, 17:28
  2. No Washers Front Or Rear!
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2011, 18:04
  3. Bulb Failures & Front Washers Not Working
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2010, 21:04
  4. Washers
    By jlock in forum Bodywork & Interior
    Last Post: 8th March 2010, 21:04
  5. Front washers trickling!
    By Jamie in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 18:08
