Results 1 to 3 of 3
Thread: heater blower only works on 4 speed
    slough
    Default heater blower only works on 4 speed
    hi guys loads of people are posting problems with this where the blower in the heater only works on no`4 position and after trying fuses and resisters and motors they find they still dont work my advice is to remove the glove box only 5 torque screws then look up under the dash left side near the door post you will see a blue relay change it and you will smile ............
    PRESTON
    hey hippo, you got the part number for this relay, i just know if i go to the stealers and say, i want the blue relay up behind the glovebox, they all gonna line up and do that monkey dance, pmsl.
    WGAF#5
    moved to the correct area of the forum
  1. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2015, 21:09
  2. Weird problem with heater blower only works with the lights off
    By evhop in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 22:02
  3. Heater Blower Issue - Only works on Position 4
    By phughes64 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 20:47
  4. Signum Blower/Fan Only Works on Speed 4
    By Gayno in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:31
  5. Heater blower only works in highest setting
    By David Schofield in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2009, 19:59
vectra c heater only works on 4
vauxhall vectra heater fan only works on 4
vectra c heaters hardly workvauxhall vectra heater only works on 4 https:www.vectra-c.comforumshowthread.php102134-heater-blower-only-works-on-4-speedmy vectra c heater blower only works on number fourvectra fan only works on 4vectra c heater switch only works on 4vauxhall vectra heater blue relayvauxhall vectra c heater blower only works on 4vectra c heater stuck on 4 settingvectra fans only work on 4vectra C fan only working on full speed heater relay vauxhall vectra
