Thread: z22se Engine Removal
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default z22se Engine Removal
    How hard would it be to remove my 722se engine without taking the gearbox out of the car as well.?
    or what is the easy way to remove the engine.
    i need to do my piston rings and mite was well do big end bearings etc..etc.. so to keep the inside if the engine clean as i have no garage that my car will fit it i though i could take the engine out of the car take it to my work space and then do the recon in there but whats the best way?
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    oh and what does the engine weigh
    Oct 2009
    Swindon
    In general I would say its easier to remove engine and box, as splitting engine and box in the car is normally a pain in the butt, however I'm not sure thats the case with the vectra so would wait for someone else to advise.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    ok great will, await somone eles even if i was to remove gearbox etc.. after engine came out of car its not that much of a problem.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    any ideas guys?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    take the engine out as a hole unit and strip it down some where clean and tidy , getting a 2.2 out isnt to bad its getting it in thats the problem lineing up can be a swine some bolts with there heads cut of some times help .also removal of the altonator / bottom crank pulley tenstioner and mounting and inlet and exhurst manifolds helps .............
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    sweet will strip it down as much as i can inside the engine bay then lift it out brilliant hahaha means i can work in the warmth lol now to tell the wife she gunna have a z22se in the front room
  1. Is my engine the z22se?
    By daytona in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 22:04
  2. Z22SE engine problems
    By amd in forum Engine & Drivetrain
    Last Post: 14th February 2010, 16:09
  3. Z22SE engine photo
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2008, 19:26
  4. Spark plug removal in z22se (2.2)
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2007, 21:39
