Thread: 2004 DTi Alarm Problems - Goes Off All The Time
    Jan 2010
    Portsmouth
    Default 2004 DTi Alarm Problems - Goes Off All The Time
    Hi all,
    Got a problem with My vectr in the way that my alarm goes off all the time when it's locked.
    I was wondering if there was any way to turn the sensitivity down or turn it off.
    I didn't realise that these were thatcham approved so I haven't actually told my insurer that I have it so their is no issue there.
    I know turning it off isn't the best solution but even sat at work I have to eithert leave the car unlocked, or constantly run outside to turn the bl**dy thing off
    Any help would be appreciated
    Nottinghamshire
    If it's an estate it might be the breakage sensors in the rear side windows.
    Also try disabling the interior sensors by pressing the alarm button at the side of the radio just before you lock the car. This will tell you if the interior sensors are triggering the alarm. If this stops the alarm going off, then check for anything in the car that could move, including spiders in/near the sensors.
    Jan 2010
    Portsmouth
    hi
    car is not estate, is a hatch
    so just to confirm, although the light doesn't flash if i press this button and then lock the car, it will turn off the interior sensors?
    Nottinghamshire
    Quote Originally Posted by vectraliam View Post
    hi
    Can't be the rear window sensors then.
    Yes, press the button and all of the alarm works as normal except for the interior sensors. It's so you can leave people or pets in the car and still lock it without them setting the alarm off.
    You can also deadlock it (i.e. press the lock button twice) until you get the alarm sorted, but obviously you shouldn't do this when there actually are people still in the car otherwise they can't get out in an emergency.
  1. Vectra Alarm Going Off All the Time
    By Vauxy in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 13:00
  2. Alarm problems - STILL !!!!
    By 798EAT in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:36
  3. How to fit an alarm on a Vectra C 2004 2.0 Diesel?
    By cornel18 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 20:29
  4. alarm problems
    By M4Master in forum Vectra C / Signum Troubleshooting
    Last Post: 1st September 2009, 13:15
  5. What alarm on 2004 1.9CDTi SXI 150?
    By VXR CDTi in forum General Chat
    Last Post: 10th February 2008, 00:15
vectra c 2004 alarm
