Thread: burning smell
    west yorkshire
    Thumbs down burning smell
    over the last couple of days i have noticed the car is getting harder to start, couple of turns before the car starts,
    when pulling up at home ive noticed a burning smell, could it be the starter motor,
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    What sort of burning smell?
    Oil?
    Plastic?
    Rubber?
    Is the burning after the run or after starting.
    On starting, faulty ignition swtch or wiring or faulty / dirty starter wiring.
    After / during a run...burning oil, or component rubbing, possible chafing of wires, tyres or other panelling
    If you are having problems starting could it be a chafed wire, loose connection or faulty component.
    Could even be a loose / damaged hose or breather expelling oil / combustion vapours into engine bay, which is then drawn ito cabin area.
    (The smell and starting issue may not necessarily be linked)
    No fault codes noted?
    More questions I'm affraid, but this may guide you to the cause.
    west yorkshire
    tbh i carnt decide what smell it is, noticed it on start up, but not while driving, but can smell it again when i walk past the car,
    just thought coz of the starting problem it mite of been the starter motor burning out, never had the smell till this happened
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Another question...
    Diesel or Petrol.
    Have a good sniff and a look tomorrow.
    Note also in this cold weather, both diesels and petrols run rich at first with quite a pungent smell of half burned / over rich fuel.
    Diesel - glow plug wiring ?
    Petrol - Engine gets much hotter therefore heat related items.
    Petrol and diesel - starter wiring / brushes, alternator wiring / brushes...rubbing drive belt, pulley rubbing on a wire or plastic component casing, tyre rubbing somewhere or getting too hot due to incorrect pressures.
    exhaust gas leaks.
    clutch or brake friction surfaces worn, causing slippage / binding and so increased heat the list goes on
    West Midlands/South Staffs border
    HI,
    Had this once, wasnt anything more sinister than a carrier bag stuck to the exhaust pipe, hopefully yours is something this simple as well.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Quote Originally Posted by neverton View Post
    HI,
    i get a smell from exhaust i use v-power diesel and ive put it down to the car not warming up i only do about 4 miles a day to work and bk
    west yorkshire
    same as me chris, been out init today and couldnt smell any thing, started 1st time too, ill just have to keep an eye on it
  1. Burning Smell
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 11:36
  2. burning smell
    By mace in forum Engine & Drivetrain
    Last Post: 7th December 2010, 21:47
  3. burning smell!
    By MARK RC in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 19:13
  4. Hmm What's that burning smell?
    By Stevel in forum The 'Off Topic' room
    Last Post: 9th March 2009, 21:22
  5. got my sri!!! burning smell!!
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 21:54
vectra smells like burning
