Thread: Changing springs do i need to change anything else?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Changing springs do i need to change anything else?
    guys i will be replacing all springs this weekend due to 2 being broken. but what i need to know do i need to replace any bolts or nuts etc while im there. the reason i ask is when u do the brake caliper carrier you replace two bolts for new ones so do i need to do the same ? thanksfor all the help
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You might want to change the strut to hub carrier bolts as they can be pretty rusty although I didn't. You might also want to change the upper strut mounts/bearings on the front as they can be problematic
    Aug 2007
    Lisburn, N.Ireland
    any idea of cost?
    WGAF#5
    bolts are around a £1
    bearings are around £15 each hth
    regards
    Dez
    Aug 2007
    Lisburn, N.Ireland
    cheers for that bought the bearings today. do you know where the supports are under the car for jacking(i know about the plastic blocks under the skirts but are there anymore?) also best places to put axle stands? cheers
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Aug 2007
    Lisburn, N.Ireland
    cheers ian
    WGAF#5
    good luck
  1. changing springs on vectra c sri
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 23:42
  2. measurements after changing springs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 19:03
  3. changing springs
    By kenny1zero in forum Handling & Braking
    Last Post: 30th June 2008, 02:12
  4. F.A.O Any1 thinkin about changing springs
    By Penfold in forum Handling & Braking
    Last Post: 17th April 2008, 16:08
  5. changing springs
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 22:45
