Thread: Strange one, lumpy rev from 1000-2000 while in neutral
    dudley
    Default Strange one, lumpy rev from 1000-2000 while in neutral
    Car Vaux Signum 53reg 2.0 Dti elite, 122k, full vaux service history, last service at 31/8/09 at 118k using longlife comma 5w30 fs oil,
    Idle is fine, no missfire or flat spots with a steady needle, but as soon as i place my foot on the pedal from 1000 to 2000, there are places where the engine kind of miss fires or stutters, only happens in neutral, in gear its fine, no smoke or judder or missfire what so ever,
    i do have a stuck open thermo otherwise its fine,
    to note in the service history, the last three services 59k and 92k and 110k the vaux dealer has used 10w40 oil, instead of the 5w30 fs anyone know why the vaux dealer would use different then the book says...?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    could be the flywheel
    dudley
    Quote Originally Posted by benny View Post
    really, thought that was felt through the clutch...? any way of testing it...? or do you leave it till it goes and then fix it
    Feb 2006
    dudley
    Quote Originally Posted by olid2002 View Post
    depends how bad it is normally you can feel it when the pedal is just moved slightly of the bottom ....but if it is totaly gone you may get a vibro try putting the clutch all the way down and reving the engine with it not in gear and see if it goes away .....other than that ya gotta have a look at the engine and see if it is missfireing ......
    dudley
    ok so clutch down and no stutter or missfire means dodgy dmf, if it still miss fires, which i think it will, then engine fault, i don't have any noise, just engine stutter, i do have the classic problem that if left for a few days I have to catch the gas at start up, and then gun it so it doesn't stall, could shot injector seals or a minor air leak in the fuel, engine side, cause this stutter,
  1. 3.2 auto g/box going to neutral
    By JG2530 in forum Engine & Drivetrain
    Last Post: 3rd May 2013, 23:31
  2. revs low in neutral
    By dan21 in forum Engine & Drivetrain
    Last Post: 8th August 2012, 19:25
  3. car running lumpy and now strange wooo sound when coming of boost??
    By richiem in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2012, 13:00
  4. Auto neutral - again
    By Robert Greenway in forum Engine & Drivetrain
    Last Post: 15th January 2009, 22:03
  5. stalling in neutral
    By woodylove101 in forum Engine & Drivetrain
    Last Post: 30th June 2008, 19:55
