Thread: Front Pad Sensors
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Front Pad Sensors
    Are these re-usable or is it recommended to get new ones when changing front pads? And do the rears have sensors?
    Oct 2009
    Swindon
    Front Passenger side only, if the warning light has come on then needs to be replaced, otherwisr re-usable if it does break on removal.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    The light also comes on if the sensor wire is damaged or broke as mine did recently..easy fix tho.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by damian s View Post
    No mate, you can't reuse it if "it does break on removal".
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Did mine!!
    west yorkshire
    intresting.
    i can hear my passenger side front brake, sounds like metal on metal, but the warning light hasnt come on,
    are the sensors fitted to 1.9cdti 120 design
    Regular Member fingers66's Avatar
    Carpe Diem
    Quote Originally Posted by tony stoney View Post
    intresting.
    What year have you got, I had the sensor on my preface 53 plate, but no sensor on my 57 plate.
    west yorkshire
    06 m8
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    intresting.
    It could also be that the pad is wearing unevenly, the sensor is only on one of the pads (the outer one). So it may be that the inner pad has worn to the metal
    Carpe Diem
    06 m8
    my facelift didnt have the sensor on it, so you better check your brake pads m8.
  1. front parking sensors
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 14:21
  2. Anyone got front parking sensors.?
    By montyfert in forum Bodywork & Interior
    Last Post: 7th June 2012, 21:55
  3. front parking sensors
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2009, 22:35
  4. Front sensors
    By Guyver1 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2009, 19:29
