Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: M.O.T Fail for LED Bulbs
    Regular Member dlm71's Avatar
    Cheshire
    Default M.O.T Fail for LED Bulbs
    My car failed its M.O.T. this morning for having LED bulbs in the side lights and number plate lights
    They actually failed the car and issued the pink VT30, i thought they might do it as advisory
    What are your views on this? do you have them fitted and have passed/failed your M.O.T.?
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    I had 'em fitted, and had the "xenon headlight bulbs" fitted too, he told me to change 'em both, but didn't put as advisory, or fail!
    Cheshire
    Forgot to mention he warned me not to refit them when i get home as the car has been noted for this defect and could result in prosecution from the boys in blue and even void my insurance
    Regular Member john-d's Avatar
    Nov 2009
    washington
    they arent illegal
    Sep 2009
    Warrington
    Quote Originally Posted by john-d View Post
    they arent illegal
    Unless of course they were an odd colour, say police blue, or yellow or something?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Mine passed with LED sidelights fitted. They are white, and other than being LED they are no different to incandescent lamps. Passed without any mention of them.
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    From the DFT website:
    1. be type approved to ECE Regulation 98 as a component.
    2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
    3. Comply with RVLR as far as "use" is concerned.
    In practice this means:
    1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
    2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
    3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
    Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
    In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
    Important notes i've highlighted in BOLD. Maybe this is what they're failing you for?
    Sep 2009
    Warrington
    Quote Originally Posted by Waterboy View Post
    He's on about LED's not HID's!
    Regular Member Matty777's Avatar
    Jan 2010
    Nr Maidstone
    Oh *X*X ....I've just ordered a set
    Regular Member vxr-i-wish's Avatar
    Nov 2009
    Quarry Bank, W.mids
    my focus passed with led side lights, just white ones, not blues!
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. Will it fail an MOT?
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 16:18
  4. HID fail
    By alijlacy in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2011, 11:07
  5. Mot fail...
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 21:16
