Results 1 to 10 of 17
Thread: help cant take this nagging whine lol
    Regular Member smithy21's Avatar
    Jan 2010
    romford essex
    Default help cant take this nagging whine lol
    my veccy has decided to develop this rubbing/whining noise it sounds like its coming from one of the front tyres/wheels can some1 help?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    take a look at the springs and see if one hasnt broken
    Jan 2010
    romford essex
    i ll have a look 2moro wen at work thanks for ur suggestion
    WGAF#5
    its more likely the disc protectors have a look around the back at the bottom - you will see a metal protective plate - its probnably rubbing at the bottom on the disc - just use a screwdriver to ply it away a little
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Wow, talk about spooky! I was getting a whining noise from my front drivers corner. Noticably bad when turning left. Put it on a ramp yesterday and it was indeed the lower disc protector plate rubbing against the disc.
    Crowbarred it straight and now perfectly quiet!
    Knew I should have posted the problem on here first, it's been annoying me for the past week!
    Regular Member Gortreck's Avatar
    Sep 2009
    Newcastle Upon Tyne
    I wonder if that could my problem too ..... could that be caused by bottoming out slightly ? I have a bumpy track which i drive daily as it leads to my property and i can sometimes catch the underside of the car on certain pieces of it where there could be a pothole or a raised bit of earth etc?
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    I get this from time to time ....so I tell her to go shopping on her own
    WGAF#5
    Quote Originally Posted by Waterboy View Post
    glad i could be of service
    Quote Originally Posted by Gortreck View Post
    as hong kong phooey said "could be"
    Jan 2010
    romford essex
    checked me springs 2day no problems there will check the protector as i do have to go down a farm track to get to work everyday so i might have bent it. cheers for ya help peeps
    Jan 2010
    romford essex
    the noise is stll there sounds like road noise but like a ressinating noise mainly here it at 30mph+ any ideas?
  1. Whine
    By Mint in forum Engine & Drivetrain
    Last Post: 29th May 2013, 18:34
  2. my 2.0 dti has got a whine
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 13:09
  3. Nagging Wife
    By nicj in forum Comedy & Humour
    Last Post: 29th January 2012, 00:27
  4. 1.9 150 whine
    By amand in forum Engine & Drivetrain
    Last Post: 15th November 2011, 16:54
  5. Nagging Women
    By Ride-On! in forum Comedy & Humour
    Last Post: 6th August 2006, 04:25
