Thread: squeaky front suspension
    liverpool
    Exclamation squeaky front suspension
    when i go over a speed hump my front suspension creaks and squeaks.i've had the local garage look at it but they said everything seemed in order but the problem persists.i was thinking about buying two new shocks,any thoughts,ideas?
    Nottinghamshire
    Quote Originally Posted by conny View Post
    May be worth checking the rubber ARB bushes first. Spray some rubber-safe silicone lubricant into them and see if the noise temporarily disappears. If it does then replace these first - a few quid from the dealer if you can do the job yourself (although you will need a ratcheting torx spanner).
    Plenty about doing this particular job on here, starting with the How2 section.
    Also check the shocks as you say. Other things on the front suspension (springs, droplinks, and also the radiator mountings) tend to make clonking or rattling or cracking noises rather than speaking/creaking.
    liverpool
    thanks james.i've read the how to and the discussion thread and would say i'm 90% sure that these are the problem i've got.
    ABERDEEN
    Default squeaky suspension
    hi i got my vectra checked out today and they reckon it is the top bearings at the top of the shocker cos when the bearing collapses as u go over a speed bump u get the squelchy squeak just a thot its been drivin me nuts
  1. Front suspension
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2012, 15:25
  2. front suspension????
    By Tayla in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2010, 17:28
  3. O/S Front suspension again!
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 09:37
  4. Squeaky suspension
    By James C in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2006, 22:27
squeekey suspension on opel vectra
