Results 1 to 10 of 14
Thread: Sky +
    Full Member spennny's Avatar
    Blantyre
    Default Sky +
    Is there a way to get the things i have recorded off my sky+ HD box, man from virgin comes wednesday , but have a few things on the HD box i would like to keep ?
    Blantyre
    Ok, should have googled, no need to inundate me with answers , as i know 15,000 have started to reply
    Step 1: Grab a DVD recorder
    Saving shows from Sky+ is simple. You could do it using a VHS recorder, but it’s a pointless exercise, since the quality will be atrocious, and your recordings will degrade over time.
    Instead, get yourself a DVD recorder, and hook it up to the Sky+ box’s second Scart socket using a Scart cable.
    Step 2: Load up on blank discs
    Once your recording set-up is complete, get yourself some blank discs. Be careful though. Not all DVD recorders will accept the same format discs. There’s DVD+R, DVD-R, DVD+RW, DVD-RW, DVD-RAM and DVD+DL to choose from.
    Have a quick look in your recorder’s manual, and then use this PriceRunner page to make sure you buy the right discs, and don’t have problems recording to them.
    Step 3: Select and copy your shows
    Now you’ve got a bunch of discs, insert one into the DVD recorder and head into the Sky+ planner. Highlight a recorded programme and press the red button to mark it for copying.
    You can repeat this process for as many shows as you like (being careful not to choose programmes longer than the DVD you’re coping them to.
    When you’ve finished marking programmes, press the Select button on the Sky remote, press record on your DVD recorder, then then press play on the Sky remote.
    Your shows will begin to copy. You’ll have to wait until they’re finished copying across before using the Sky set-top box again, although you can press any button on the Sky remote during the process to cancel copying.
    Must-have accessories
    Scart cable – You can connect your Sky+ box to a DVD recorder using a standard aerial cable, but you shouldn’t. The quality won’t be anything near that offered by a Scart lead. Pay a little more, and you’ll get shows in the same quality they were recorded which, thanks to Sky+, is the same quality they were broadcast too!
    Regular Member Keithtmoir's Avatar
    Jan 2010
    West Lothian
    Dont disconnect the box leave it attached to the telly you can still get itv HD on the Hd Box you wont get that from Virgin
    Blantyre
    Quote Originally Posted by Keithtmoir View Post
    Not to fussed mate, the ITV HD channel only broadcasts certain times of the day , the woman just asked me last night if i could record or get the programmes from it , should have searched last night
    Regular Member SRimonkey's Avatar
    wednesfield
    you work for virgin anyways ya won`t pay for any channels lmao
    Blantyre
    Quote Originally Posted by SRimonkey View Post
    Get a mahoosive discount only, saving myself currently £70 compared to Sky
    wednesfield
    get it 4 me an all
    Blantyre
    get it 4 me an all
    I can
    If your in a cabled area
    wednesfield
    i`ve got broadband an telly off em..........just wanna pay less than 50 quid lol
    Winteringham
    can you get a discount for exisiting users ????
