Thread: Side light problem
    Oct 2009
    Preston
    Default Side light problem
    I'm new to this forum and a total numpty at any car maintenance.
    I have had a bulb warning light on my dashboard for a few weeks now but I'd never been able to work out which bulb wasn't working however in the last few days I've noticed that my front drivers side sidelight isn't working but instead, the indicator light is permenantly on. I've had a few people flash me recently and although I've never known exactly what for I can only assume it's because my sidelight appears to be glowing orange rather than white.
    I had a look under the bonet at the weekend in an attept to work out what bulb I need to replace and couldn't work out how to get to the sidelight bulb. I've changed a headlight bulb in the past with some difficulty but this one seems totally buried and impossible to get to. Am I going to have to take it in to the garage just to get a bulb changed?
    Any help or advice gratefully received.
    West
    Replace the front offside side light mate... taking the airbox out helps access
    Oct 2009
    Preston
    I'd worked out it needs replacing, I just don't know how.
    I have no idea what the airbox is, what it looks like or how to take it out.
    Any advice?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Its the big black box in the left hand corner of the engine bay, you need to remove the hose coming out of it, remover the lid and then it pops off of the rubber mounts
    West
    lol...
    Glad you worked it out
    The airbox is the big plastic box infront of the headlight, it houses the airfilter... remove that & you will be able to see better
    Failing that a trip to the dealer to be charged a fortune lol...
    Shame your not near me, a local motor factors near me does all the hard work by fitting builbs etc... & only charges for the builb
    Nottinghamshire
    The Vectra uses the adjacent indicator bulb when the front sidelight bulbs blow. I've not changed the front sidelight bulbs in the yet, but it is covered in the manual if you have a copy. If not, you can download one from the vauxhall website in PDF format.
    There are at least 3 separate covers on the back of the headlamp unit for the various bulbs. If you are feeling brave - and perhaps until some who knows for definite which cover the sidelight bulb lives beind posts - I'd start with the cover directly behind where the sidelight bulb is located.
    I think you can get away without removing the headlight on a pre-facelift car (http://www.vectra-c.com/forum/showthread.php?t=68943&highlight=replace+sidelight) although removing the air filter box and waher bottle neck does provide more room, but there's less room in a facelift so you will need to remove them - or move the leadlight unit forward as per the pictures in the How2 section (http://www.vectra-c.com/forum/showthread.php?t=15060).
    Guide how to identify your headlights here - http://www.vectra-c.com/forum/showthread.php?t=89453.
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Hi..I managed to change my side light bulbs for an ice-white set..Didn`t have to remove lights or airbox but it was tight mind..Have a facelift sri.Drivers side defo worse than passenger..
  1. LED side light problem
    By SRIRob in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 19:23
  2. Brake and Side Light Problem
    By itdaveh in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 22:51
  3. Vetra Estate near side tail light problem
    By Groughy1` in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2011, 10:13
  4. mtec side light problem
    By mccluskey119 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2010, 15:45
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
vectra side light out but indicator glowing orange
vauxhall side light out but indicator glowing orange
vectra c left side light on
how do i take my side light bulb out of my vectra c
vectra c side:profile
