Thread: Rear pad light?
    hull
    Default Rear pad light?
    hi all,
    got the veccy in garage today for a new cambelt kit and new rear pads.
    question is when the rear pads are low would this bring my red handbrake light on? as it keeps coming on now and again? or have i another problem?
    West
    Low brake fluid brings the handbrake light on... check the level
    Regular Member Jezzy's Avatar
    S.E
    It means your brake fluid is low (or the sensor think so anyway).
    hull
    thanks guys,
    that adds up, i noticed the fluid was low last week.
    i'll check it again once i get it back from the garage, it should go back up with new pads shouldn't it??
    West
    It should go back up with new pads, just get the guys at the garage to top it up while it's there
    May 2008
    Tetbury, England
    the guy at my local vx dealership said that only the front brakes trigger the warning light when the pads are low, the rear ones do not. buuut obviously this does not neccessarliy mean this is true.... you know how they are!
    West
    Quote Originally Posted by irondan View Post
    that's correct in terms of the pad wear sensor...
    the OP is referring to the handbrake warning light, which also doubles up as a low brake fluid warning light...
    hth
  1. random mod, anyone converted the rear ashtray to light up the rear?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 02:21
  2. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
  3. Rear Fog Light
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2006, 08:56
