Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
Thread: something for the weekend (LED Driving Lights)
    Swindon
    Default something for the weekend (LED Driving Lights)
    Sat at home bored, thinking what can i do to the car, at low cost, but have a huge impact.
    Then it hit me LED driving lights.
    so off to ebay i go. found these
    http://cgi.ebay.co.uk/2x-New-48-LED-...item3efa9af3c8
    delivered within 2 days. 1 hours work. and hey presto, all fited, come on with the ignition. no issues, no problems. just excellent visual effect
    I'll add beteer pics later, but really easy to fit.
    Jul 2009
    The Rift, Cardiff
    Looking mint mate, I like it.
    Are they on the bumper and how did you attach them?
    Regular Member gaz4d's Avatar
    Glasgow
    They look good !!!! I'm interested.
    How have you fitted them ? i.e. location, have you removed the headlight or bumper ?
    We need better pics !!!! preferably with them switched off, so we can see how you've done it.
    Swindon
    Just popped outside and took some more from the phone
    They are very easy to fit. They fit between the headlight and the bumper.
    loosen the headlight screws on top of the headlight. Squeeze between the gap and then tighten back down the headlight.
    wiring goes direct to the multi plug socket on the back of the headlight unit.
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    Quote Originally Posted by tonyt View Post
    mmmmm i may invest in some
    Regular Member Keithtmoir's Avatar
    Jan 2010
    West Lothian
    Nice easy looking job was it ebay you got them from and how much might need to do it to mine
    Swindon
    easiest and cheapest mod i've done. great visual impact. Work as daytime running lights for the front only.
    All other lights work ok. it doesn't interfere with the Check Control system.
    Happy days. All for under £10
    Swindon
    ebay link at the beginning of this thread. very easy to do.
    you will need the following tools
    8mm socket ( headlight )
    Torx screwdriver for the 4 screws that run along the top of the bumper into the slam panel
    Soldering iron and solder
    Voltage tester
    If any one needs help, let me know
    Glasgow
    This sounds good and quite straightforward...(apart from the electrical and soldering bit lol).
    The way you have set them up........ do they go on with the sidelights, or are they permanently on when the ignition's on ?
    Swindon
    permanently on when ignition comes on.
    If you wire to the side lights, when you turn ignition off they will flash because of the check control system, pulsing for 30 seconds after the power has been turned off. Also, when you start the car they will flash unless you turn your sidelights on.
    So not advisable
  1. Relays for front driving lights
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2012, 17:25
  2. flickering lights when driving anyone had this prob?
    By robshortman in forum Diesel Engine related
    Last Post: 22nd November 2010, 13:45
  3. Replies: 13
    Last Post: 20th September 2009, 22:14
  4. foglights as driving lights..
    By kenp in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2009, 14:56
  5. This weekend I shall be mostly driving.....
    By MattB in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 18:19
