Results 1 to 10 of 19
Thread: signum 3.2 elite petrol
    Aberdeen Scotland
    Default signum 3.2 elite petrol
    Hi am new to here, I am looking to buy a 3.2 V6 signum 03plate 63kmiles manual petrol. i went to view the car and take it for a test drive. It drives good and the interior body work is in excellent condition for the elite spec. Problem is under the engine oil cap there is a residue of yellow colour. Also there is a oil leak in engine but cant see where from. I need help as in
    1. Is the yellow colour in oil cap cause of water in oil, Or is it cause has been sitting at garage over winter? Is this fixable? Can it cause damage in future?
    2. There was a drop of oil under car where it was sitting then took it for a drive, parked up then a new drop of oil on groung where it was then relocated. Looked in engine bay and seems to be oil down to the bottom right og engine. Is this rocker cover gasket? is it major or is it anything that can be sorted fairly cheaply?
    i really like the car and want to purchase it but these things are putting me off it and making it a risky buy.
    Any help please as dont want to miss out on car. thanks.
    Aberdeen Scotland
    Default exhaust
    there is also a slight puff of smoke at front of exhaust from engine any ideas on fixing this and prices thanks.
    11 Post(s)
    Quote Originally Posted by iam2103 View Post
    Problem is under the engine oil cap there is a residue of yellow colour. .
    Most likely short trips and not letting the oil fully get up to temperature to burn off any moisture in it.
    If in any doubt, get a sniff test done on the coolant header tank.
    Aberdeen Scotland
    Thanks do you have any idea about the oil leak, and do you recommend going for the car?
    Northampton, UK
    The 3.2 V6 is a great engine! Add it to a Signum and its still what I wish I'd bought instead of the 2.0T.
    Regular Member Jezzy's Avatar
    S.E
    You need to be careful with the oil leak. Whilst the mayonaise in the filler cap is often just the result of too many short journeys, the leak is a different matter.
    The GM V6s (2.5, 2.6, 3.0, 3.2) can suffer from rocker cover gasket failure, either caused by warped plastic rocker covers, and/or the oil breather pipes getting blocked, which causes too much pressure in the crank case, which causes the oil leak.
    Have a read of this thread, starting from the posts on 3rd February this year and onwards:
    http://www.vectra-c.com/forum/showthread.php?t=92469
    Aberdeen Scotland
    Thanks jezzy. So if it is the rocker cover gaskets is this cheap to fix? Would the car still be good when this is fixed? Read the link and it does point to the rocker cover gaskets but I dont want to purchase if big job. Thanks again.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    http://www.vectra-c.com/forum/showth...ghlight=filler
    Might put your mind at rest.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    If you're good with spanners, then no more than £20-30 for 4 rocker cover gaskets from VX. Thing is, the plenum chamber has to come off to get to the covers. Otherwise, about 1 hours labour.
    So depending on which garage you use, £70-150 inc parts.
    Aberdeen Scotland
    thanks alot for the quick replies. So the oil leak after the test run is probably mostly due to the rocker cover gaskets needing replaced? The link top the mayonaise in oil cap has made that clearer and is aneasy solution thanks. The car has full service history but at 63k i dont think the belt has been done yet, what mileage is this usually done at? Is it expensive?
  1. Swap petrol to diesel, Vectra to Signum, Elegance to Elite
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2012, 20:26
  2. Vectra 2.2 petrol elite gearbox whine, I think......
    By pt9091 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 09:41
  3. Things to look for on a 2.2 Petrol Elite
    By Spud163 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2009, 14:42
  4. 2.2 petrol elite
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2008, 20:01
  5. Petrol Direct 2.2 Signum Elite
    By Small Racer in forum Engine & Drivetrain
    Last Post: 20th February 2008, 19:32
