Thread: My 1.8 petrol sounds like a diesel!
    Ireland
    Default My 1.8 petrol sounds like a diesel!
    Hi all,
    In the last few weeks my car has developed what can be described as a diesel-type sound when idling. It's especially apparent when I pull up outside my house and the sound reflects off the wall. Could almost be described as a "tapping" sound.
    Anyone have any ideas on what it might be? The car had an oil & filter change approx 5K miles ago.
    Thanks!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I wonder if it could be timing belt tension....
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    don't know if it's a 1.8 thing but mine is 1.8 sri serviced last week and only done 27k and it's also quite rattly/tappety........i think it's a trait of this engine tbh
    Regular Member cphaza's Avatar
    Hertfordshire
    depends how tappety...have you taken the oil cap off (carefully) while idleing to see if oil is getting up to the top?
    Aug 2009
    i'll give it a look tomoz, cheers for the advice...is there anything that can be done if it turns out not enough oil getting up there or something
    West
    my oil burner doesn't tappety tap
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    if its the z18xer engine fitted in all 1.8 after 2007 i think . they have problems with cam pulleys for variable valve timing also need fully syn oil as well
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by paul wingnut View Post
    The above problem tended to show up mainly when the engine is first started from cold, as the oil needed for the pulley hydraulic tensioners had a habit of draining back when left over night. Modifed oil valves were later fitted to try and effect a cure. This problem was very prominent on the 1.8vvt engine on the new Insigni'a also, until VX introduced some modified one way oil valves 3 months after I complained.
    What may be causing the OP noise is the 'Tank Vent Solenoid' I had one go faulty myself on a 1.8vvt Insignia and they can be really noisy.. like a very loud tapping noise. When mine did it, at its worst...my wife and I thought there was a helicopter hovering right above us it was so bad.
    Even normally the vent solenoid will make a little noise but usually more of a ticking noise, hold your hand on it, and you can physically feel the solenoid vibrating...ie operating the valve inside. Later mods have been introduced by VX to try and insulate the unit with a special rubber mount as most of the noise originally was being caused by the unit resonating through the car bodywork. Certainly worth checking out, and can quickly be eliminated if not faulty.
    Ireland
    Thanks for the comprehensive reply!
    Is this something that can cause permanent damage / engine damage over time?
  1. Petrol car sounds like a diesel
    By spennny in forum Engine & Drivetrain
    Last Post: 14th November 2010, 02:05
  2. signum 1.9cdti sounds like a turbo petrol why??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 18:14
  3. 2.2 direct sounds like a diesel ???
    By wanna veccy in forum Engine & Drivetrain
    Last Post: 1st September 2010, 13:48
  4. PETROL vs DIESEL?
    By vectrahuw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2008, 00:07
  5. Petrol vs Diesel
    By kryton01 in forum Diesel Engine related
    Last Post: 14th September 2006, 06:49
z18xer diesel sound
z18xer diesel noise
opel vectra 2008 petrol sounds like a diesel
vectra c sri 1.8 has started stuttering sounds like a diesel
vauxhall insignia sounds like a diesel
opel vectra b sounds like diesel
vectra sounds like diesel
