Thread: Vectra-B brakes sound like metal to metal
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Vectra-B brakes sound like metal to metal
    Brakes sound like metal to metal
    Folks,
    when my car gets warm and it comes under heavy braking, it sounds like it metal to metal, like a drone.
    the front pads are ok, so are the rear one's, whats left?
    The rear shoes cant contribute to this can they? I havent checked them but I would assume that the shoes are only controlled by the Handrake and cable?
    Help please.
    Car is a 2.2 SRI DTI 130 / 51-reg - Vectra-B.
    Thanks.
    11 Post(s)
    Have the discs got a lip on the edge of them?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you tried cleaning the handbrake friction surface by slightly applying the handbrake and driving forwards about 100m?
    I assume you know that the handbrake operates separate braking surfaces to the normal service brake?
    Birmingham
    No idea, didnt check this but will do.
    Quote Originally Posted by Ste View Post
    Nope, I will gove this a whirl.
    Please explain a little more Ste, im somewhat confused. Thanks.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The service brake (ie foot brake) operates the disc pads - just the same as on the fronts.
    The handbrake operates conventional shoes in the hub inside the assembly - just as a drum brake works.
    So the setup is both disc and drum, for foot and hand brake respectively.
    Occasionally you have to clean the handbrake shoes and drum inner of carps, rust etc by doing the above mentioned procedure. It is in the handbook.
    Birmingham
    Ste, what you say is actually incorrect, the back does not have any shoes inside the disc. Look at this how2 about removing and changing the rear discs, there is nothing inside the disc.
    As for my metal to metal, I have had the rears stripped down and replaced and the lips of the discs grounded off and re-bled, etc etc, and still the same.
    Do you guys think new discs and pads on the rears would help me with my problem?
    Thanks.
  1. Sounds like metal-to-metal from the rear.
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2014, 12:01
  2. Vectra c clucking from drivers side wheel (cracking metal sound)??
    By smithonline in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2011, 11:28
  3. metal sound?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 12:04
  4. Metal like creaking sound from the back of the car
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 17th September 2008, 10:23
  5. metal sound under car
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 26th March 2008, 20:23
