Results 1 to 10 of 21
Thread: 2.2 Non Direct Idle Control Valve
    South Wales
    Default 2.2 Non Direct Idle Control Valve
    Can anybody provide me a picture of where it is (idle control valve) i was told where it was earlier.....but seem to be missing it :s or maybe i think its something else lol
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There isnt one on the Z22SE mate.
    South Wales
    oh f**k there goes my idea of that being the reason the engine dies everytime i dip the clutch at a junction.............any ideas as to what could cause it?? im going to clean the egr valve and the thottle body ( thats at the front of the engine right??)
    Vehicle : SRi
    Mileage : 137000
    The gap around the butterfly controls the idle, if it gets dirty it can affect the idle.
    The EGR is this, mines blanked but its still bolted to one side.
    South Wales
    Smile
    ok so the butterfly is inside the Throttle Body yea?? and is the bit i've marked on here the egr valve?? (totally new to this sorry im basically going to give it a go myself just want to know if i'll be cleaning the right thing.
    Vehicle : SRi
    Mileage : 137000
    No mate the EGR is that silver barrel shaped thing.
    This is your TB
    And the butterfly..........
    South Wales
    ah thanks dude absolute legend!! is the egr pretty straight forward to remove?.... the butterfly is pretty dirty actually i cleaned out the maf sensor and took the pipe off and it had a fair bit of oily much over it.
    Vehicle : SRi
    Mileage : 137000
    EGR is just 2 bolts and a plug, tbh they dont really get that bad on the 2.2 petrol. Mines only blanked as I was going to change the manifold but ended keeping it standard.
    South Wales
    ah ta I am thinking of changing it for a 2.0 SC TB and a 2.4 Manifold...just wondering would it need mapping to run smooth or would it still run well without a map?
    Vehicle : SRi
    Mileage : 137000
    Its the 2.4 manifold I have in my cellar. I never fitted it because I didn't want to lose torque which is what will happen unless you upgrade the zorst manifold as well, and with that on a C you also need a sports cat and custom down pipe as the Vec C's Cat is built into the stock manifold. The 2.0SC TB needs modifications to the loom and also a custom mounting plate. Courtenay and TMS do a map just for the 2.4 manifold and yes it would really need a map to get the best out of it.
  1. idle control valve 1.9cdti 16v
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 1st October 2012, 10:03
  2. **Urgent help required - Idle Control Valve gasket**
    By Bloicy in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 18:13
  3. 2.0 Turbo idle control valve
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 14:13
  4. Help! 3.2 Idle Control Valve Gasket Needed (Leeds)
    By Hedgehog70 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 12:39
  5. where is the idle air control valve on the 1.8 16v?
    By glencol in forum Petrol Engine related
    Last Post: 18th March 2008, 08:41
idle control valve vauxhall vectra 2.2
vauxhall vectra 2.2 petrol idle control valve location
idle control valve vectra c
vectra 2.2 petrol idle speed control valve location
https:www.vectra-c.comforumshowthread.php101987-2-2-Non-Direct-Idle-Control-Valvepage2
vauxhall 2.2 petrol idle control valve
vectra c 2.2 idle control valve
vectra c z22se idle control
vectra b 2.2 petrol idle valve location
Icv clean vectra 2.2
