Thread: White Smoke From Engine
    Oct 2009
    _
    Default White Smoke From Engine
    Another fault with my Vectra.
    I would say 2-3 times a month now the engine decides to smoke. It's white smoke and smell like oil/diesel which rises from the engine bay. Today it happened when my wife nipped out to the shop but drove OK on the way home. The car runs fine otherwise, no smoke from exhaust and has been recently serviced. As it's only happening now and again, I can't get out and see exactly where it's coming from. Anyone give me advise on what to check or has experienced this too? Oh, and it's not my wife's driving!
    Oct 2009
    _
    Meant to say car is a 1.9CDTI 120, 06 reg.
    dover
    If you find out please let me know mine is a 19 tdi 150 but intermitently does the same thing it's happens twice in last two months White smoke from under bonnet seems more from drivers side under wheel arch but can't find out source as clears after about 20 seconds smells like parafin but car runs perfecly
    preston
    check for leaks in hoses.
    has someone vented crank oil pipes to atmosphere??? before you got it?
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Crank case vent to atmosphere will emit blue smoke and would be all the time and it smells like burnt oil. White smoke is def diesel it sounds like a injector or leak off pipe could be leaking onto te hot engine. Are your cars estate or signums or have auto gearboxes
    preston
    maybe but white smoke could be condensation within venting system if it was opened up.
    Possibly also have a look at turbo , make sure no oil leaks from there
    dover
    No oil leaks At all car uses no oil or water and runs perfectly this happens once in a while and I do loads of motorway miles hard to see where it comes from because it clears quickly. Buy when it does this it's a lot of smoke. Ps it's an auto estate
    kings lynn, norfolk
    I bet it's your dpf doing a regen and I you have a little split on your exhaust gasket or egr gasket and the gasses can get past when doing a regen will stink with White smoke too mate
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    flexi pipe i bet mine was same....mine signum by way
    dover
    May be just that looked and think I may have a small blow from flexi pipe went through mot no problem though ****** lot of smoke when it does it though
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  4. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  5. Cold Start - White Smoke - Juddery Engine....?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 11th September 2011, 23:17
