Thread: 1.9 Boost Sensor and EGR Valve clean
    Regular Member djr69uk's Avatar
    Midlands
    Default 1.9 Boost Sensor and EGR Valve clean
    Today I took off boost sensor and EGR valve to clean them, as I've noticed a bit of hesitation about 1.8-2k revs sometimes. I am running a tuning box, but this hasn't caused any probs in about 15k of running. I've taken off EGR valve 10k ago so it wasn't too bad... but the main problem I noticed was that where the EGR connects to the manifold, it was all coked up there on the manifold side, almost completely blocked - this is after I cleaned it last time. So this time I had a good poke about with a small screwdriver and sprayed some carb cleaner in there too. Loads of crud came out - and I mean loads.
    Then when I took off the boost valve I noticed this was completely enclosed in crap. So sat that in a cap of carb cleaner for an hour, then sprayed it directly with the carb cleaner and it started to look like a boost valve after a while lol!
    Popped the lot back together and she started first time - thankfully - was a little worried about my excessive use of carb clearner lol! Anyway, noticed immediately that the throttle response had improved - this is very apparent. Then took it out for a blast and everything felt spot on. Pulls a bit harder again but power delivery seems smoother and the idle is spot on. I know people can clean car parts and then the placebo effect kicks in - but this was a definite improvement. No hesitation now at 2k either.
    I'm wondering how safe it would be to spray loads of carb cleaner into the manifold where the EGR joins... I know there is a ton of crap in there. Anyone done this without any probs?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    thats one thing i wanna do on my vectra the egr, its done 45k now and the last owner had it from new and he was 65 so i dont think he would of done it lol, you know the coolant hoses how did you stop them from leaking? thats the only thing stopping me from doing mine unless i change the coolant at the same time,
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Theres no issues that i am aware of regarding cooling hoses mate just have to move 1 hose out the way a bit to get to one of the bolts it dosent need to be disconected.
    Aug 2009
    herts
    No coolant gets affected.
    I agree the torque curve on the acceleration is so much smoother now.
    I carb cleanered my inlet manifold entrance too, and when it started up poor with spanners and eml lights on when driving, I was worried. However as I have detailed over this site, It was the solenoid pin drill, tap remove and grease problem... Now all is well
    Oct 2009
    Sandwell
    sorry mines a dti so its got to be different to yours in the how 2 its states
    You will see 2 pipes leading into the valve,these are coolant pipes and need to be removed.
    Use a pair of pliers to compress the clips and slide them off,place a rag underneath the pipes as there will be a small amount of coollant that will drain from them.
    The pipes are very easy to remove..BUT have something ready to plug the ends with..i used 2 10mm bolts which i just quickly screwed into the ends,this stopped the pipes draining.
    Midlands
    Quote Originally Posted by hertscol View Post
    reckon it would be ok to spray liberally inside the manifold? what are thoughts on this?
    May 2007
    GLASGOW
    After i cleaned mine i noticed the car runs at a higher temp than before!
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Quote Originally Posted by LEW1S2006 View Post
    i noticed the same thing is that a good thing or bad :O!
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Quote Originally Posted by djr69uk View Post
    i sprayed directly inside rubbed it all down works a lot better no EML so should be fine
    (reply is very late but for future reference)
  1. Boost sensor clean
    By Ruffus2 in forum Engine & Drivetrain
    Last Post: 14th August 2012, 18:22
  2. Clean boost sensor?
    By mikeq in forum Engine & Drivetrain
    Last Post: 15th June 2011, 17:57
  3. Boost sensor clean!.
    By felixx in forum Engine & Drivetrain
    Last Post: 18th July 2010, 23:37
  4. Boost valve clean, how do i???
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 22:39
  5. de badged, airbox mod and clean boost valve
    By li4m in forum Quick Photo Album
    Last Post: 4th January 2010, 19:34
