Results 1 to 10 of 11
Thread: help with hid query
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default help with hid query
    fitted my hid kit today(35w 6000k) hid direct, well pleased and both are working but i have a slight discrepancy in that the one side seems to point higher than the other giving the impression that one side is brighter than the other, my problem is that i'm not sure which one is at the correct height , the drivers side seems less bright but it does look to be pointing lower than the passenger side one, as i said they are both working and i was gentle putting the bulbs in so am sure i hav;nt moved the light position, could it be that the bulb may have dislodged or anyone had any similar thing happen to them and if so how or what was the remedy..........cheers guys and sorry for another hid thread, any advice received with thanks
    Regular Member antowns's Avatar
    Nov 2009
    Amble, Northumberland / Ryton, Gateshead
    hi mate
    I have also just fitted 35w 6000k HID's and my passenger side seemed to point a little up. I took it apart again and noticed that the metal bulb holder had popped out of the clip, so i just put that back in and its all sorted
    Try having a look to see if its popped out the clip......
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    my left one is a tiny bit higher aswell , but output from both sides kicks halogens out the water so im not fussed like
    Jun 2009
    Newcastle
    Quote Originally Posted by antowns View Post
    hi mate
    you know the rules antowns where's the pics?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'd suggest the old favourite of parking a measured distance from a wall and measuring the heights of each 'flat' section of the pattern.
    I'm sure any number of us could do the same and tell you which height is correct.
    Or.... pop down to a local garage and bung it on the beam setter...
    (The wall idea is cheaper)
    Nov 2009
    Quote Originally Posted by shaun260589 View Post
    lmao will do mate ill post them in that thread i opened the other day cheers for offering to help me tho, real gentleman
    Aug 2009
    thanks for the quick reply guys i'll have a look in the morning to see ip/s one has moved cos it was more difficult to pop in than the d/s one so i'm hoping it's as simple as that..............cheers guys
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    PICS !!
    It's the LAW !!
    Regular Member maurauth's Avatar
    Southampton (Locks Heath)
    Quote Originally Posted by dilan View Post
    if you're a facelift then pop the bumper off it's a lot easier that way
    if you're pre-facelift then I can't comment on the space behind the lights for fitting the kit
    Aug 2009
    went out to check it this morning, so i stripped all the air box etc out of the way and sure enough the d/s bulb had come loose in the clip, managed to get it to stay put and both lights now bang on, i'm not sure if it'll stay in place though cos it was quite loose, anybody have any similar problems and if so what did you use to wedge it in so it don't come out again
  1. H.i.d kit query??
    By Marcosuk in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 20:07
  2. GSI query?
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2011, 10:38
  3. BSR Query
    By Jezzy in forum Petrol Engine related
    Last Post: 26th January 2010, 17:35
  4. Tow bar query
    By Agoogy in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 08:52
  5. GM Oil query
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2006, 11:43
