Results 1 to 10 of 20
Thread: Air lock nightmare
    Regular Member Shrimpy's Avatar
    Jan 2010
    Blackburn
    Default Air lock nightmare
    Hi all,
    I've just changed my thermostat as it would only read 70 when it decided to work at all !
    The swap went ok but as I topped up the coolant and turned the bleed screw it sheared off
    My problem now is that I think I have an air lock but am not 100 percent as the heaters are blowing hot.
    The guage hasn't moved at all since the swap although the engine has def warmed up.
    I've tried parking on steep slopes both directions squeezing every hose I can reach but to no avail.
    I am wondering how the heaters can be hot but no sign of temp on the guage and also can I run the car with an airlock without doing any damage?
    Ps . There is coolant weeping out from the remenants of the bleed screw.
    Thanks everyone , can't believe I chose a Sunday to tackle this one!
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    this might sound stupid but the electrical connector on thermo housing is on ok ?changed mine yesterday if heaters are hot doesn,t sound like air lock all pipe work hot ?if not release pressure on bottle run engine with cap off see if any bubbles come up if not put cap on check pipe work again ..
    Jan 2010
    Blackburn
    Cheers Paul , Ill check the connection but Would a bad connection not chuck up an error code ?
    Does anyone know if jamming my garden hose into a specific hose will blast an airlock out or would that cause more problems ?
    Pete
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    On my old cars i use to leave top off expansion cap and let car run you will hear when the air has been expelled
    Irmscher Insignia CDTI 130
    Dunstable
    did this on my cav, left the cap off, ran the engine...few bubbles would come out for a while then calm down.....couple of times it errupted all over the place....so just keep an eye on it
    Jan 2010
    Blackburn
    Cheers . I'm out here now on my Iphone so I'll keep you posted
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Thermostat should open at approx 86 degress which will then circulate around the car so its at that point when any airlockl is likely to expel. Vx recommend 2-2.5k for 2mins. then idle for 2mins, then 2-2.5k for 2mins then idle till the fan cuts in... or something like that
    durham
    would not try hose in these dont normally suffer air locks was housing new one or copy part just thinking may be a faulty sensor if guage was working before might be worth swapping sensor over why dont you if you have put plenty of coolant in it at least 2 liters of anti freeze and some water taking car for a run if heaters are warm its more likely to be ok sometimes diesel's take forever to warm up when standing still the problem you might have is the broken screw . good luck m8
    Jan 2010
    Blackburn
    The thermo was own from vaux. Am trying the exp top off run at half then idle for a bit until the fans kick in.
    If the fans don't kick in am I really in the sh?! ?
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    take cap off expansion tank,
    them keep squeezing one of the coolant hoses to try and pump air out
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Nightmare
    By marko1966 in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 19:26
  3. Never mind lock up ya daughters, lock up ya vectras!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 21:45
  4. Had a nightmare day!!!!
    By BIG NEIL in forum The 'Off Topic' room
    Last Post: 6th February 2009, 10:29
  5. Nightmare
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2008, 21:35
vectra c airlock in coolant
vectra c air lock
