Thread: SRI Suspension
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Default SRI Suspension
    I have read dozens of threads about the suspension set-ups and am thinking of replacing my standard set-up for the SRI shocks with VXR springs for a 20-25mm drop on standard. The SRI shocks I am told are shorter than standard and firmer than standard to help pre-load the SRI springs so fitting these shocks should help with the VXR ones I plan to put on.
    Question is do I have to change anything else like the top mounts to fit this set-up to my car?
    Cambridgeshire
    I think the top mounts are all the same mate. However, you may want to replace the roller bearings (strut bearings) while you are there and have everything apart.
    I think I recall Kman replacing the shocks in his Elegance for B4's and he used the same top mounts with no problems
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Bump
    Leicester
    If your going down this route, fit SRi shocks and springs, Fitting VXR springs is a really bad idea as there is engine weight difference between 2.8T and 1.9 CDTi.
    By doing the SRi kit, you can buy the srpings that are the right match for your engine.
    But you can keep everything else in your strut set up.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Cheers mate but mine is an auto also and so the axle weight at the front is almost identical within 15Kgs mine being heavier strangely enough.
    Leicester
    Ah, OK didn't realise you had the auto which is heavier. But surely you would get the same effect from proper SRi springs from an Auto?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    I have SRI springs for the weight range but 1 is bust the VXR springs came up that offer a further upto 10mm drop and as I have 18" wheels the SRI setup seems a little tall. If the VXR ones don't work I can put the SRI's on with the SRI shocks I am getting just wondered about issues that all but seems that theres none really cheers for the responses.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Will all go straight on matey
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    put on upgraded springs. tbh after failing my mot for 2 of them snapping i wont trust vx springs again
  1. suspension
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:40
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. suspension!!
    By leonvectrac in forum Handling & Braking
    Last Post: 11th September 2008, 23:20
