Thread: Odd electrical faults
    Nov 2009
    Milton Keynes
    Default Odd electrical faults
    Hi Gang
    had a few odd electrical things recently - started with cruise control not working on one journey (not repeated but I don't use it very often) ...next the CD70 won't change radio channel without being switched off first (this is intermittent and happened four or five times in the last couple of weeks) and then today, start the car and the power steering light comes on and steering very heavy - immediately switch the ignition off and it works again.
    In the last three months it's had a new alternator and then in the last six weeks the dreaded injector three problem...
    it's a 06 SRI estate 1.9CDTi 150 - 64k, owned since new
    any suggestions?
    cheers Mart
    Mileage : 000
    Probably not the answer to correct the faults. But have you tried disconecting the battery for a while. You never know it might re-set things?.
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    Dodgey replacement alternator/connections maybe??
    Nov 2009
    Milton Keynes
    Thanks Guys
    I'll give it a go next weekend - car's due for a massive valet soon so if the weather's okay...
    MM
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Does the light come up on the cruise control? My clutch has a weak spring or something, when I press the button it lights up for about half a sec and goes off, I have to put my foot under the pedal and lift the pedal up and then press the cruise control button.
    Sep 2009
    warwickshire
    hi, have you had the battery tested ?
  1. My new car faults!
    By ScottyV6 in forum Engine & Drivetrain
    Last Post: 26th September 2012, 22:09
  2. [Vectra C] [02-08] 03 sri water in foot well but now have many electrical faults
    By gavin1981 in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2012, 21:51
  3. Electrical Faults????
    By mikemac in forum Vectra C / Signum Troubleshooting
    Last Post: 12th May 2011, 19:41
  4. Electrical Faults HELP
    By mikemac in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 18:02
  5. VEC FAULTS X2 Anybody help???
    By DonMafia in forum Introduce yourself.
    Last Post: 25th January 2009, 17:02
