Thread: engine cuts out
    ringwood
    Default engine cuts out
    hi all
    iv just bought a vectra 3.0 v6 auto diesel which has been running fine, but driving home last night the engine kept cutting out and i had to roll to the hard shoulder to re-start the car. when it cuts out all the electrics still work its just the engine.
    i gave up with re-starting the car over and over again, so i phoned the RAC, they came out and plugged the laptop in but no faults were found. i then drove the car today to a garage and they couldnt find the problem. no warning lights come on but today the traction control light stays on when i was driveing the car but the engine still keeps cutting out. it seems to cut out when the car warms up.
    iv checked the battery and all the fuses and there fine.
    if anyone has had the same problem or nows what the problem may be im open to ideas
    thanks very much
    thedhj
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 2.8T 280 vxr
    Trim : 280 vxr
    Engine : 2.8t
    Is it a clean cut off or a juddery one?
    Recently my engine was cutting off as though i had turned the ignition off (no judder at all). The fault with mine was faulty crankshaft sensor
    But tbh it should give back the fault codes for that :/
    mine was 0335
    Im also having problems with my automatic transmission now though code 0700
    ringwood
    yeah its as if id turned the engine off, the reves drop straight to zero and the car slowly comes to a stop.
    how much did your cost to repair?
    thanks thedhj
    Jul 2009
    Derbyshire
    Trim : 280 vxr
    Engine : 2.8t
    Well mine is a 3.2 v6 gsi
    I took mine to a local garage and he charged me £35 for diagnostics, £31.20 for the sensor + VAT.
    It came to £79 ish but he didnt charge me a hours labour for some reason so that would have knocked it up to around 120
    It may be a job for vauxhall to look at though if it isn't bringing up a fault code. If it was the crank sensor you should have a code.
    ringwood
    ok brilliant cheers
    one more thing, when your engine cuts out, would it be when the car was warm, and would you be able to start the car again and then would it do it again further up the road?
    thanks
    Jul 2009
    Derbyshire
    Trim : 280 vxr
    Engine : 2.8t
    yes mate.
    Id be able to drive for about say 10miles before it would cut out. It'd cut out clean and it wouldnt start straight away (id have to give it about a minute) but then it would start no problem and it'd do it agian a bit furthur up the street (for some reason though after the first cut out id be able to keep starting straight away, it was only the first that wouldn start straight away)
    But as i said mate, mine gave fault codes. If your's isnt giving codes then i wouldnt advice just changing things without knowledge if its that at fault as your's may not be the same problem as mine was
    Its worth a try to clean it and check the wires etc though id say
  1. 2.0 Dti engine cuts out Signum
    By martutd in forum Engine & Drivetrain
    Last Post: 19th March 2012, 08:35
  2. Engine Cuts Out at low speed
    By rocket999 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 12:04
  3. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  4. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  5. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
vectra zc 3.2v6 traction control light stays on after starting
vectra zc 3.2 engine cutting out
https:www.vectra-c.comforumshowthread.php101877-engine-cuts-out
