Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: CHIPPED UK RE-MAP DAY 24/06/06 (not 56k)
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Default CHIPPED UK RE-MAP DAY 24/06/06 (not 56k)
    An excellent day out today at Chipped Uk in Bromsgrove
    Great to meet everyone.
    I had my 3.0 V6 CDTi re-mapped by Jayson, firstly Jason tested my car on the rollers in standard form.
    At this point I got a slap on the wrist as I had neglected to remove my CRD2 before arriving this morning and the fuel pressure was still well down(if you are considering a re-map remove your box at least 300 miles prior to having re-map work carried out as this helps Jayson get correct readings)
    It is a long process on the 3.0 engine due to the ECU having to be removed, the ECU then has to be dismantled and the e-prom chip removed.
    Stripped out ECU
    Once the chip is removed Jayson reads the code from the chip onto his laptop, this is the origional file which he sends to his programmer.
    E-prom chip in reader, connected to laptop
    The programme is re-written increasing fueling and boost, other perameters are altered to suit the increased boost and fuel map, maf and lambda settings, overboost cutout etc.
    Once the programme is rewritten(about 2 hours) it is sent back to Jayson and he then uploads the progamme to the e-prom chip, this is then tested to ensure that the 'checksum' matches the origional file(if it doesn't match Vauxhall can tell it's been modified and will void engine warranty) the e-prom is then re-fitted to the ECU and Jayson then does a quick test on car before final sealing and assembly.
    Jayson does quick test to ensure all is Ok
    Once the ECU is reassembled and re fitted to the car its back onto the rollers
    And the results are then compared to origional figures
    My Graph. Dark ble and red are after re-mapping
    I can only say big respect to Jayson for doing the car and for honouring his price of £225 for my car.
    After seeing how long and how in depth he has to go to re-map the 3.0 and 1.9 CDTi's I can understand why the cost is higher.
    Needless to say I'm very pleased with the results and the figures will improve once the car has bedded back in and fuel pressure is restored.
    On the drive home, 210 miles, the car just seemed to improve, and the graph figures really do not display how well the car performs.
    My figures with the CRD2 were excellent and to be honest I was extremely happy with the way the car performed, but now with the re-map it certainly performs just as well all through the rev range, no smoke at all and it will improve, which it seemed to have done by the time I arrived home where I used my private runway for a spirited run up to 145mph and still pulling strong.
    In conclusion, the box was excellent but there is no substitute for a proper re-map
    A few pictures of the day
    Jamie removing bug splatt
    GSi 3.2 on the Rollers
    Mark after returning from his roadtest in the newly re-mapped GSi 3.2, note the HUGE grin
    Pimm's car on the rollers, it has the most beutiful exhaust note I've ever heard on a V6 engine
    Spikeys car on the rollers
    Graph of single run showing Bhp, Torque, Rpm and Speed
    Graphs as viewed on computer prior to printing off
    Mark's Speed and RPM readout during the run
    After the arduous tasks of the morning we retired to a local hostelery for a bit of lunch
    Leighton Buzzard
    Great photos Robbie, lovely to met you again, great day had by the GSi household and what can only be described as interesting drive home!!!!!
    Dec 2005
    In the sponge-monkey tent
    Great pics and write up Robbie, your smile when you got back from your test run was probably the biggest of the day, second I think was Jayson's when he got back with you! lol
    Dec 2005
    Quote Originally Posted by Mrs GSi
    I gather you found a couple of 'disused airstrips' on your way home then
    Regular Member Geoshaw's Avatar
    Armadale (West Lothian)
    That is one very flat torque curve robbie, it must be so smooth now and just keep pulling.
    Looks like you're figures may well be down due to the fuel pressure being too low as you said. You're standard run shows the car is down about 20hp!
    I think if it is rolling roaded again after a few miles are put on it, you're figures will be back up again.
    p.s. todays date is the 24th
    Dec 2005
    Quote Originally Posted by Spikey©
    Oh yes, I'm still grinning ear to ear now
    Dec 2005
    Quote Originally Posted by Geoshaw
    Yes George, Jayson said figures were well down due to fuel pressure, but he has no control over it, it goes back up to normal after around 200 to 300 miles.
    The run home has made a big difference and it's still going to improve
    Based on standard figures of 184 Bhp and 400 lb ft, I'm going to be around the 220 Bhp and 450 lb ft once everything settles down
    Chuffed/ Pleased, You Bet
    Quote Originally Posted by Robbieben
    blimey chap .... thats alot of donkey !!!! can i intersest you in a little drag strip action in august ?????
    you know just to test it out
    Sounds like a productive day all in all!!!!
    Regular Member Ian's Avatar
    York
    Nice write up Robbie, and a cracking result too! Good on yer for your honesty mate - you cant argue with that bhp/£!! Well done mate, glad your chuffed
  1. Another 3.2 been to see Chipped UK
    By Trel in forum Petrol Engine related
    Last Post: 19th September 2006, 01:18
  2. just been to chipped uk
    By trucker in forum Tuning
    Last Post: 26th August 2006, 16:43
  3. Chipped Uk Re-map 24/6/06
    By PIMM in forum 2006
    Last Post: 26th June 2006, 14:37
  4. Chipped UK 24/6/06
    By Spikey© in forum 2006
    Last Post: 26th June 2006, 08:08
