Thread: Clio with bubbles in header tank???
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Default Clio with bubbles in header tank???
    Hello all,
    Bit off topic but got the mrs's 98 clio up to running temp earlier and noticed it was sat a little above half way.. which is a bit high for a 1.2 when its only 1 degree outside.
    Popped the bonnet and noticed in the header tank tiny tiny bubbles rising from the bottom. (Like when you put water in a pan and start heating it). Normal? and a little bit of auto paranoia? Or something serious?
    The coolants not mucky and the oils not emulsified, but would be nice for some other opinions...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Normal mate, remember the car is circulating the water around the engine, as long as its not losing coolant all should be fine
    Ashington, Northumberland
    Its not normal for air bubbles to be bubbling up in the header tank. Get the car engine to operating temp and then SLOWLY, and allowing the pressure to escape, remove the cap from the header tank. Now get someone to rev the engine while you watch the coolant in the tank. If it bubbles up or volcanos over the top, you're looking at a head gasket.
    The oil will only emulsify if the head gasket has blown between an oilway and the water jacket. If the head gasket has blown between the water jacket and a cylinder, then the coolant system will pressurise via cylinder compression, causing bubbles in your header tank.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sorry for the way I put it, I meant it can sometimes look like bubbles when it is actually just the water circulating, propper air bubble I agree are not normal. Worth getting it sniff tested too
  1. vectra c 1.8 sxi small bubbles in header tank
    By vectra-man in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2013, 14:55
  2. header tank cap??
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 23:15
  3. Emmisions Light, bubbles in expansion tank
    By nabber68 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2010, 19:07
  4. header tank cap
    By animal22 in forum Engine & Drivetrain
    Last Post: 6th March 2009, 14:52
  5. Header tank.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2008, 21:41
