Results 1 to 10 of 21
Thread: HID Confusion :(
    Regular Member antowns's Avatar
    Nov 2009
    Amble, Northumberland / Ryton, Gateshead
    Default HID Confusion :(
    Hey guys,
    Im just installing my HID's which i got from HID-Direct and im a bit confused
    Have I got them layed out correctly?
    If so why have i got spade connectors on the two leads that go into the cars orignal wiring
    Can someone help me out? sorry if im missing something obvious
    thanks
    You should have a pink block with it all mate that connects in to the plug on the inside of the headlight. The spades aren't fitted to it as the wires have to go through the plug that fits on the headlight. The plug is fitted on the picture above,...
    Sunny Dartmoor
    I plugged the 2 wires into the old headlight bulb multi-plug,been working for over a month now...........
    Nov 2009
    Quote Originally Posted by Penfold101 View Post
    I dont have any pink blocks mate
    Ill have a go glen see if i can do it the same way
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Didn't have any pink block with mine, just plugged the spades into the connector black into the negative and red into positive.
    They must have changed the kit then. This is the one I got from HID's Direct at the end of 2008:
    http://www.vectra-c.com/forum/showthread.php?t=28225
    Blantyre
    Quote Originally Posted by tramman View Post
    same as mine, straight into the spades
    Correct Penfold, they have changed them, no pink blocks now ,
    Quote Originally Posted by spennny View Post
    So I'm gathering....
    Blantyre
    Unless :
    Yes, how would I have coped without the pinkness in my car...
  1. SMD confusion
    By MattVecVXR in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2013, 22:01
  2. DPF confusion.
    By JayF in forum Engine & Drivetrain
    Last Post: 7th April 2012, 10:00
  3. TID & GID confusion
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 18:28
  4. HID confusion
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 15:08
  5. air box confusion!!!
    By littlesxi in forum Diesel Engine related
    Last Post: 7th February 2008, 09:29
