Results 1 to 10 of 13
Thread: Fed up with this poorly made car, advise wanted
    Oct 2009
    Swindon
    Default Fed up with this poorly made car, advise wanted
    This car is driving me mad, in the 6 months we've owned it I have changed:
    Rear upper suspension arms
    Rear ARB bushes
    Full service
    Front disks and pads
    Changed supersport kit for Bilstein kit
    Then yesterday I replaced:
    Front ARB bushes
    ARB Drop Links
    20x new wheel bolts as the stupid torx headed wheels bolts ans key snapped
    Changed above due to knocking, this has vastly improved it, however there is still a slight knocking.....what do I look at next, it appears to be drivers side only, I have new strut top bearings to go on, and I am think should I also change the top mount (which contains the void bush) at the same time?
    All that will be left to do after this would be the front wishbone and rear wishbone bush, track rod end appears to be fine and I can't see rad mounts making a knocking like this.
    I have also been doing mods to the car at the same time, must have spent £1K on it........still needs 2x new front tyres and I have camber bolts to go on whilst a 4 wheel alignment is carried out!
    Can anyone advise on the likey cause, or even give me an idea of where to look next for this knocking? it notices when going slow and sometimes when braking at low speed, kind of a knock, knock like something moving forwards and back again......
    I've never had so much trouble tracking down and fixing a knocking noise.......I think the Vec B was built better!
    Oct 2007
    Shropshire
    Mmm, knocking can be a ****** to fix. When does it do it over bumps, when steering etc?
    Oh and I don't think you can blame disc + pads, wheel bolts and service on the car been badly made! And most of the other parts you replaced could easily fail due to lowering...
    Oct 2009
    Swindon
    Yeah suppose your right, just hacked off at not being able to fix knock.....and it seems like I have spent a fortune...oh well...
    Has anyone replaced Top mounts? as these are £40 a side so wondering if it's worth it, they don't appear to be worn.
    It does it at low speed on rough ground, sometimes when you brake to stop and sometimes when you steer, only at low speed 10mph or less..
    Oct 2009
    Swindon
    After a long drive today I think its as bad as it ever was!
    IT's either top mount/bearing or a problem with the CV joint....
    hull
    veccy suspension is cr*p IMO.
    You just replace one part after another
    Oct 2009
    Swindon
    Yep, looks like im on a systematic replacement of the complete front end suspension.......cheap ass poorly made rubbish, well until you want to buy an original spare then it's ££'s more than it should be!
    Regular Member slick91's Avatar
    Jul 2009
    Newcastle
    Quote Originally Posted by damian s View Post
    Rear ARB bushes
    Full service
    Front ARB bushes
    ARB Drop Links
    aye i have some advice mate burn it
    Oct 2009
    Swindon
    lol.....it had crossed my mind, but as its the wifes car really (I have a company car) I don't think she would be too pleased. I think I have a grip on it now, going to spend some time on it tomorrow..
    Jul 2009
    Newcastle
    lol she would never notice mate hahah
    Oct 2009
    Swindon
    Finally sorted it in 1/2 hour today.....removed strut and steering bearing was way past it's best, lots and lots of play, stuck a new one on and peace at last!!!
  1. My poorly car is going in I can't take it no more
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 10:27
  2. Car is poorly :(
    By sjk in forum Vectra C / Signum Troubleshooting
    Last Post: 16th December 2010, 13:58
  3. Is it poorly?....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:22
  4. Poorly VXR
    By MattB in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 10th August 2007, 20:29
  5. Poorly
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2006, 15:39
