Results 1 to 10 of 18
Thread: Lock Nut Help
    Scotland
    Default Lock Nut Help
    Guys,
    I was just changing back pads and got the first changed no problem went round to do second and the security lock nut on wheel (kind of rounded star shape) is stuck and now began to thread . What is best and cheapest solution to get the nut off .
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    New locking nut key from the stealer
    Scotland
    Default Nut
    Unfortunately its the bolt on the car not the key
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Ah thats not so handy, do a search on here this has been covered many times
    Scotland
    Default Thanks
    Ok thanks will try see what i can find
    Scotland
    Default Right first time
    John you were right first time ha ha
    I went looking found a bolt that screws over the top from halfords to remove it. It stated on website if had free spinning outer guard may not work so i though i would go check to see if they had by taking other one of and the key just slide so the key is goosed.
    Anyone know if they have the free spining guard?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yeah they do unfortunatly
    Fareham, Hampshire
    This happened to me on the M40 i got a puncture and had exactly the same problem.
    I had to take it to a garage where they have a specalist tool for it but you guessed it due to the spinning sleeve they didnt work.
    To get it off in the end we had to snap the spinning collar off using a small chisel/Screwdriver and then we had to hammer a slighly smaller socket over the top of it and then just undo it as normal.
    Big job though, i suggest if you have breakdown from home, i would call them out they will do it for you. (Just put your other wheel on and flatten your tyre and pretend you have a puncture so you need to put your spare on they should do it for you lol)
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    your nearest tyre fitter/ tyre bay will be able to remove it for you for about a fiver
    Scotland
    Default Many thanks
    Many thanks guys for responses
    Bogz dotn have any cover and cant get any of the wheels of as key is knackered
    after much searching and a few phone calls.
    Local tyre fitters want £11 per nut.
    Called local dealer with the code (188) which i found stuck to the back of the spare tyre cover in boot. They qoute £27.25 for new set and he is checking now.
    So if i get them off there going in bin and i will use normal nuts
    Worst case i will split spinning guards and socket them off
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. air lock
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2012, 10:54
  3. Never mind lock up ya daughters, lock up ya vectras!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 21:45
  4. lock nut?
    By twaiter in forum West Scotland
    Last Post: 31st August 2009, 18:06
  5. Air lock?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 02:26
