Results 1 to 10 of 19
Thread: Different tyre sizes front and back?
    Regular Member kevvyboy's Avatar
    West Lothian
    Default Different tyre sizes front and back?
    Quick question.....as the title suggests can i run matched pairs but of slightly different sizes front and back?
    Currently need 2 front tyres, running 215/50 all round (no pun intended) and would like to move to the 225/45 for choice/cost, and replacing the rears in several months.
    That sound ok?
    Regular Member Thestig's Avatar
    Cumbria
    Not sure i'd want to go far and wide without the same all round but it dosn't sound as though its that big of change so should be ok, having said that i'm currentlt running 14" snow tyres on the front of my Cav while having 17s on the rear i just use it for work though not far to travel.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep absolutly no problem doing that and there are many members on here that have done so. Might I suggest you put the new ones on the back to wear the 215/50's out a bit quicker
    Stoke-on-Trent
    Vehicle : Mazda 3
    Trim : Sport
    Engine : 2.0
    I've been running like that for twelve months with no problems, wished I'd put the 215/50's on the front though, but I'm soon due a set of all four and will be buying 225/45's.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    legally no problem as long as the same axle has the same size tyres fitted. New tyres should always go on the back. For info I found Camskill 215 tyres slightly cheaper than 225.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    why would going from a 215 to a 225 mean going from a 50 to 45 sidewall?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    As the side wall is a percentage of the width so if the width goes up the percentage goes down to keep the sidewall roughly the same
    Jun 2009
    South Coast
    would that not change the circumference of the tyre though and therefore the put the speedo out?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Minimally, by about 1mph
    West Lothian
    aye, one of the calculators in the stickies puts the difference at 1.9%
    ie speedo=60mph, actually doing 58.8ish
  1. tyre sizes
    By chris1804 in forum Handling & Braking
    Last Post: 19th January 2013, 13:22
  2. Which tyre sizes
    Last Post: 5th October 2012, 00:42
  3. tyre sizes
    By mrpatterson2008 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2010, 17:50
  4. Tyre sizes
    By Biff600 in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2010, 20:33
  5. Tyre sizes
    By MLC in forum General Chat
    Last Post: 15th January 2009, 23:50
