Thread: Code PO135
    durham
    Default Code PO135
    Hi all
    The other day had my car in for a tech 2 for the Sat Nav. The management light was on so asked the guy to tell me what it was on the quiet. He has given me the code PO135 o2 sensor / heater circuit. Can anyone pin point exactly what this is and does anyone have a pic of what it looks like?
    Once again..... cheers
    Martin
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
    It is located in the manifold befor ethe catalyst and measures the oxygen content of the exhaust gas stream. From this O2 measurement, lambda can be calculated and any trimming to fuelling can be made to keep the air fuel ratio optimum (normally engines run under lambda control most of the time).
    If it stops working, then the ECU doesn't have a measurement of O2 to tell what exactly is going on, and so can cause slight fuel economy penalty and also slightly drivability drop too.
    Worth getting an OE part too for these
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    sorry mate forgot to tell you what code was for first o2 sensor heater circuit sensor in manifold did you have any luck with radio decode ..
    durham
    before you change sensor check fuse fe1 and fe15 in fuse box under bonnet next to batt voltage supply for heater circuit
    durham
    Quote Originally Posted by Ste View Post
    Thank you very much fpr the reply.... so its the top one one on the manifold / CAT section?
    durham
    Quote Originally Posted by paul wingnut View Post
    No mate still a nightmare... been on tech 2 - head unit will not recognise the code I have for it so going to have to try to get it decoded... do you know anyone locally?
    cheers Martin
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. Ecu code
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2011, 17:45
  3. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  4. code for cd 40
    By Eddie Dee in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2007, 01:16
  5. Key Code
    By HB39AA in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 15:50
po 135 saab 93
vectra p0135
