Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 76000 miles its my turn! Car gutless, no power under 2k and wobbling like a baddun
    Aug 2009
    herts
    Default 76000 miles its my turn! Car gutless, no power under 2k and wobbling like a baddun
    Last two days when engine started up cold.
    No power, no revs, no guts. Struggles up a hill, and is like an old escort diesel van without a turbo! Actually worse.
    EGR has been off, and I used Wynns EGR3 through the system and was running great.
    The swirl rod ends are fine, but do look a little coked and gummed up and around the base part circular dials that rotates on the inlet manifold itself.
    The EGR or the Inlet Manifold has failed. Get the spanner light come up under acceleration, but then clears as the turbo kicks in and the car then goes rapid in higher revs.
    inlet manifold or egr?
    Mar 2007
    GB
    Difficult to know, obviously Tech2 is your best bet. Could also be an injector issue. Assuming this is a CDTI you have, the 3rd injector wiring sometimes plays up causing very rough running. Could try cleaning the contacts. You might also be unlucky enough to have a shot injector, does happen
    Jun 2009
    Glasgow
    Got a similar prob my self mate....rough idle and a kinda pinking/detonating noise when accelerating.Just fitted new inlet manifold and 4 injector plugs....no joy!!I dont have any fault codes or spanner light!!Im thinkin iv got a duff injector.
    Jan 2010
    Doncaster
    hi mate,,, had this problem myself, cleaned out the egr as always the usual but ended up been the wiring on injector 3, try checking this out cause as hideous said this is also a quite common fault, fingers crossed.
    Aug 2009
    herts
    Its had the 3rd injector upgrade already.
    Jan 2010
    Doncaster
    not to sure about that then, next thing would be to see what the tech2 brings up,
    Aug 2009
    herts
    I'll get the boost valve out and take off the egr again tomorrow, soak it and see on refitting.
    Aug 2009
    herts
    EGR off, seperated, blasted and soaked in carburettor cleaner.
    Boost Valve cleaned.
    Lots of smoke came out of the back on rebuild and restart.
    On first drive here was power and the delivery under 2000 revs was a bit better and there was more go over the 2000 rev flat spot.
    The spanner light does NOT come on now, however, a NEW fault, the car has gone into limp home mode and the engine management light eml is on with no power-as if the turbo is not spooling up.
    Pleeeeeeaaase help...
    Aug 2009
    herts
    AA Out
    Fault code 2279-suggests EGR Valve or air intake issue
    Im thinking MAF or just needs me to buy a new EGR Valve.
    Thank god for Breakdown repair cover, booked in for Mon Morning
    Aug 2009
    herts
    Great how to!
    It was the SOLENOID!!!!! Stuck and needed drilling, tapping out and lubing.
    How one little pin affected the running of the whole car. Once again, anyone with EGR trouble or severe, seVERE loss of power under 2k as if the turbo isnt working and any spanner lights coming on, or eml light and fault code read is P2279 on obd.
    Im confident this is it! Drill out, tap out clean and lube the solenoid pin as here....job done!
    http://www.vectra-c.com/forum/showth...ght=egr&page=3
    My car is a raging bull again, and pulling strong from 1k revs upwards!!! Oh Yes!
  1. gutless 150 cdti below 2k
    By alan opel in forum Engine & Drivetrain
    Last Post: 6th December 2012, 19:30
  2. gutless but no limp
    By krisby in forum Engine & Drivetrain
    Last Post: 3rd October 2011, 15:02
  3. My turn for no power under 2000rpm in Vectra CDTi (150) SRi
    By Ollie in forum Engine & Drivetrain
    Last Post: 27th March 2010, 18:40
  4. 2nd gear gutless
    By vauxie in forum Engine & Drivetrain
    Last Post: 25th June 2009, 13:54
  5. Gutless Sri
    By scott davies in forum Engine & Drivetrain
    Last Post: 2nd February 2007, 21:59
my car is gutless
