Results 1 to 10 of 17
Thread: poor starting
    Jan 2010
    Herts
    Default poor starting
    Hi all,
    just bought a 57 CDTI 1.9 estate. All fine but it takes a couple of turns of the starter to start, this happens with a hot or cold engine.
    Is this something to worry about or typical for the vehicle?
    Sep 2009
    Swindon
    When I start mine I turn it to ignition 2 and leave it for about 5 seconds, then it will start first time. If I just get in and try to start straight away it won't start, I assume the glow plugs need a few seconds to get hot, maybe others can confirm?
    Frenchman
    N.Ireland
    Quote Originally Posted by kmx racer View Post
    Hi all,
    Quote Originally Posted by frenchman View Post
    Frenchman
    KMX RACER.sounds like there is a problem of some sort,could be the glow plugs,is the car with spanner coming on at the start and then going away.The car should start first time unless it,s really cold,then you would need too turn on ignition and wait for the plugs to heat for about10 seconds or so,
    Jun 2009
    Midlands
    I assume the plugs only heat up whilst the glow plug coil light is illuminated? Having a similar problem with cold starts but the engine light extinguishes on start up. Plus, thinking about it, the glow plug light is only ever on for a few seconds max even on a chuffing cold day! Any clues?
    Jun 2011
    Dunfermline
    i am having the same problem as KMX Racer warm or cold. i have to keep the key cranked untill its totaly fired up. i can turn the car off then 1 min later try to start it its just the same takes a long time to fire up. in the morning i use the glow plug light even tried a couple of turns with the glow plug light . but makes no differance hot or cold. i have a 1.9 cdti it runs fine as i use it for a taxi. i asked a vauxhall mechanic and he said EGR before i could finish explaining my symptoms ! think he just dont carer as he only fits them he dont have to pay for them. lol. oh and i had a new EGR fitted a year ago it made no differance
    Jun 2011
    Dunfermline
    Quote Originally Posted by GarthTax View Post
    Jun 2011
    Dunfermline
    Sorry about that double post im new here & dont know what i am doing
    Apr 2011
    Newark
    confused
    From the number of posts regarding problems with 1.9cdti engines starting from cold there is obviously a problem with them. Its just a shame that there doesn't appear to be a definitive answer to what that problem is.
    West
    Firstly when was the car serviced... Fuel filter clogged or filter housing with a tiny crack will cause the fuel to flow back towards the tank.
    What's the battery like, if the battery is fine then the starter motor itself could be at fault, in addition to this a failing dmf can cause the starter to fail or hamper starting speed.
    hth
    Jun 2011
    Dunfermline
    I service my car probably more than it needs as i use it for a taxi. Battery is fine. I thought it may be air getting in and allowing fuel to run back. The same problem the old Vectra used to have where if you parked it up hill it was hard to start and if you parked it facing downhill it was easy. It feels kind of like the same problem. But tried this parking both ways makes no difference and also can’t be this as it is bad to start even if you switch off and try to start straight away. Only thing i can think of is dust from the dmf in the starter as i read somewhere some one thought starter was ok but changed it anyway and was starting like a new car. But i don’t know i thought i will leave it till something breaks down then i will know for sure. But it just keeps going. Sometimes you get a good car sometimes a bad car. Think this one is a good one. LOL
  1. Poor Starting
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 2nd May 2012, 23:55
  2. poor starting
    By tomo610 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 19:21
  3. Poor starting
    By Croxley in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 20:25
  4. EGR and poor starting
    By dhwigston in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 22:07
  5. poor starting
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 12:14
vectra c 1.9 cdti slow cracking www.vectra-c.com
