Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Replacing Multi-V Belt - Any Tips?
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    Default Replacing Multi-V Belt - Any Tips?
    Morning all,
    I'm replacing my v.squeeky Multi-V Belt tomorrow and just wondered if anyone had any tips on how i can make it as easy as poss. Is it worth taking the airbox off? Any special tools needed, etc?
    Cheers.
    Regular Member old cruiser's Avatar
    slough
    Funnily enough mate I'm doing mine this weekend also for the same reason and looking at it I reckon you could do it without removing the airbox and attacking it from under the car, however I think I'm gonna remove airbox as I reckon that'll make it easier, looks a straight forward job (he says!!) i.e remove air box for easier access , remove side cover, de-tension the tensioner and slip belt off and new one on, at least i hope it's gonna be that easy!!
    Cheers Pete
    Aug 2007
    Cheers Pete, having a (quick) look at it last night i think thats how i'm going to do it, just wanted to be aware of any nasty little suprises before i make a start. Got the rear pads to do as well so dont want to waste any time really.
    Good luck with yours mate!!
    slough
    hi guys. you may want to check your belt tensioner they seem to play up and cause a squeal
    Aug 2007
    cheers matey, i'm going to have a look whilst i'm messing about and see what its like, hoping the belt will sort it out, just to save me the pennies as much as anything!!
    May 2008
    Tyneside
    Check the length of the old and new belt which is printed on the outside. It's not uncommon for the wrong belt to be supplied.
    slough
    Quote Originally Posted by Terry Tibbs View Post
    And you with yours mate and out of interest what size is your new belt mine has 1028 written on it, but had a look on TIS and spec says 1030, however on EPC it calls up the 1028 for aircon which mine has, just strange theres's that 2mm difference .
    Cheers Pete
    slough
    How did you get on Terry? I tried to fit the belt this morning but gave up as I can't get any of my tools down to the tensioner (square hole) as there is just not enough space between tensioner and body, is there a special tool available to do this?
    Cheers Pete
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    the one supplied to me (yet to fit it) is a 1030
    slough
    That's interesting mate, had a look on EPC and doesn't seem to be a 1030!! have you got the part number to hand at all?
    Cheers Pete
  1. best multi car and multi driver company policy providers?
    By zerocool in forum Insurance Chat
    Last Post: 9th May 2012, 14:32
  2. replacing 1.9cdti aux belt
    By stevie16v in forum Engine & Drivetrain
    Last Post: 14th October 2011, 14:55
  3. Timing belt/chain replacing
    By rob123 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 19:41
  4. Replacing tie rod any help/tips appreciated
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 14:18
  5. any tips on how to cut the rear valance to show my exhaust tips
    Last Post: 2nd July 2008, 18:58
