Thread: Nightmare day!
    Chelmsford
    Default Nightmare day!
    Thank god it's now the following day...
    Was out earlier in town and started hearing a strange rattling/scraping/crunching sort of noise from the nearside back corner. Pulled over and took a look and the tyre was totally flat (it was almost worn out anyway, would have been very upset if it had been one of the new Michelins on the front!). ****** great big bolt was jammed in the tread! Put the spare on and carried on my way.
    As if I hadn't had enough car trouble for one day, it then started running very roughly, I was getting a horrible judder when I hit the gas in neutral and it was badly hesitating under acceleration. Felt like a mis-fire and the EML had come on.
    I called the AA, the guy plugged his diagnostic machine in and told me that it was showing a mis-fire on cylinder 2. He said it was most likely a faulty coil pack.
    When I told him that I'd recently had to swap the radiator because of a coolant leak, he said that the leak, combined with a mis-fire, could possibly point to a dodgy head gasket.
    Anyone care to comment on this? I know the coolant problem definitely wasn't down to a worn head gasket (I collected the leaked anti-freeze in a bowl as it dripped out of the radiator!).
    Anyone else had to replace their coil pack? My car is a 1.8 petrol on an 04 plate.
    I did a full service a couple of weeks ago and replaced the spark plugs. New ones came from Halfords, Bosch somethings... Could it be that one is faulty?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The best thing to do would be a compression test. Is there water in oil, or oil in water? Maybe a sniff test would also be a good idea to see if any combustion gases are in coolant.
    I would also check the tightness of the spark plugs and also check security of the coil pack onto the plugs.
    To check if number 2 plug is faulty you could always move it to another cylinder and see if the mis-fire moves with it.
    Seeing as it is a 04 1.8, you can probably get any fault codes by doing the pedal method of blinking out the codes and then look them up.
    Chelmsford
    Quote Originally Posted by Ste View Post
    Please tell me more!
    Didn't know there was a way of getting the codes without all the kit.
    I was a master of the Vectra B paperclip method, if there is something similar for the C, I'd love to know!
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
  1. ABS nightmare!!
    By jonno1103 in forum Introduce yourself.
    Last Post: 26th March 2011, 00:29
  2. What a nightmare!
    By vxr-i-wish in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 20:54
  3. Had a nightmare day!!!!
    By BIG NEIL in forum The 'Off Topic' room
    Last Post: 6th February 2009, 10:29
  4. Nightmare
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2008, 21:35
  5. Nightmare!
    By RJPITCH in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2007, 20:03
