Thread: Clicking Gear Knob
    Jan 2010
    Wigan
    Default Clicking Gear Knob
    The gear knob has started with an anoying click on my 56 Signum, as you are changing gears it presses down very slightly and springs back up clicking on both the downward and upward motion. It is only the knob on the gear stick thats moving and clicking, everything else seems good. Anyone else had this??
    How do you remove the knob to investigate further is it just a case of unscrewing it from the stick??
    Cheers.
    Ste
    I've got this on mine mate. The knob itself needs a hammer underneath to release it as it appears to be an interference fit. Best bet is to go on eBay and find the whole assembly including the gaitor and mechanism. If you lift up the gaitor on yours, you'll see 4 torx bolts the hold the whole thing in place. Remove these and the two ball joints and the whole thing comes out. Takes about 5 minutes to do...
    Jan 2010
    Wigan
    Thanks mate will have a go tomorrow as its driving me mad!!!!
    Regular Member sdnatlst's Avatar
    Nov 2009
    Cambridgeshire
    are there 4 torx bolts on the 2.2 sri vectra too? i cant see how to remove the stick on mine laos having the problem with not being able to get the nob off!
    Yes mate, they're all the same as far as I'm aware. 4 torx bolts, the bit white plastic joint that control the forward and rear movement, then the small ball joint at the bottom that contorls left and right movement. That's all there is to it...
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    My Vectra estate does this occasionally too!
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Just wait till your knob falls off - then wack it back on with a bit of wood and a smeer of araldite on the shaft.
    Did this last year, and been fine ever since
    Quote Originally Posted by JagRigger View Post
    Reminds me of American Pie...
  1. show me your knob (gear knob)
    By justin32 in forum Bodywork & Interior
    Last Post: 10th October 2011, 19:18
  2. Metalic clicking noise when changing gear? Osf
    By Craig1985 in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2011, 19:24
  3. Play in my knob gear knob lol
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 16th June 2010, 08:20
  4. Clicking Gear Knob
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 17:24
vectra c gearknob clicks
