Thread: Squeeling Brakes
    Jan 2010
    Wigan
    Default Squeeling Brakes
    Changed discs and pads on my 56 Signum a couple of weeks ago, everything has been spot on but over the last cuple of days there has been a squeeling when you brake lightly (undecided as to which side its coming from).
    Now before anyone suggests it i lubed the rear of all the pads with copper grease so i'm assuming thats not the problem, any ideas as always are welcome.
    Cheers.
    Ste
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Did you also lube the sliding surfaces on the pad into the calipers with copper grease?
    slough
    did you use genuine parts or cheep copies?
    Regular Member Jezzy's Avatar
    S.E
    There's a small shield near the underside of the caliper, make sure it isn't touching the disk.
    Jan 2010
    Wigan
    Thanks for the replies, they are genuine vauxhall parts. Can't remember if I lubed the spring clips which locate inside of the front pistons I will strip it down and check over the week end, is this where you mean Ste?
    Will also check the shield on the under side of the caliper are these on front and back?
    Thanks again for the replies.
    Ste.
    Nottinghamshire
    Quote Originally Posted by Griff72 View Post
    Ste.
    The shields are behind the disks - a flat metal plate that covers most of the rear surface of the disks.
    You don't lubricate the spring clips - Ste means the 'hooks' on the pads that slide along the caliper brackets as you apply/release the brakes.
    My genuine GM pads squealed a lot and so I replaced them with EBC Ultimax - no squealing and much better stopping power.
    S.E
    Forget the word "hook", that causes confusion...what people above are saying is that you need to put grease on the bit of the side of the pad that slides along the caliper when the piston is pushing it. That friction between the side of the pad and the caliper can cause noise. Putting grease on the back of the pad, as you've already done, stops noise from the piston-to-pad contact point, not caliper-to-pad.
    Jan 2010
    Wigan
    Quote Originally Posted by James24 View Post
    Ok I know the 'hooks' you mean, will have a good mooch tomorrow and report back thanks for the useful info.
    Ste
    Jan 2010
    Wigan
    Thanks Jezzy, I think I'm with it now, lube along the top edge of the pads (when they are sat in the carrier) the side in contact with the caliper.
    Am I right in remembering the 'hooks' are only on the rear pads?
    Ceers.
    Ste
    Nottinghamshire
    Ceers.
    Ste
    Sorry, I should have been a bit clearer - I didn't mean the locating hooks on the front inside pads (that clip them into the piston) or the spring-like thing on the rear inside pads (that brace them against the inside of the caliper).
    I meant the hook-shaped part at the top and bottom of the backing plate of each of the brake pads - i.e. what they slide along the caliper mounting bracket on whenthey are moved backward and forward by you applying/releasing the brakes (and as the friction material and disks gradually wear down).
    The backing plates are pretty much the same shape on the front brakes as on the back ones, it's just larger on the front than on the back.
  1. Squeeling sound :/
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 13th October 2012, 07:59
  2. Squeeling from engine
    By Gortreck in forum Engine & Drivetrain
    Last Post: 14th December 2010, 14:51
  3. Engine Squeeling when started, hot or cold
    By benparker in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 16:56
  4. Squeeling brakes
    By sy_uk in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2010, 13:37
  5. Brakes squeeling
    By S14RRJ in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2008, 00:44
