Results 1 to 10 of 13
Thread: urgent ,inlet manifold removing question
    Sep 2009
    suffolk
    Default urgent ,inlet manifold removing question
    the garage , rang me today to say i MIGHT have too pay for a new cambelt because they think it may have to be removed , when changing the inlet manifold ? seems strange to me coz it was only changed 10k miles ago and they may want £130
    Jul 2009
    N. Ireland
    mmm, not sure buddy, mine is only out from Vx after having a new inlet manifold and there was no mention of needing a new cambelt. I had my timing belt done when there were changing the manifold but only because it was gona need done in another 2k miles,
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    cambelt is no longer required to be removed when changing the inlet manifold as per Vauxhalls guide, the cambelt kit is approx £90.... Would be advisable to do IF your due if not then leave it alone
    edit, changed 10k ago, tell them to leave it alone and do the job without touching it...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I had mines changed when I had the manifold doen and thank God, as the water pump was goosed and could of went any time.
    Personally if you can afford it get it done especially if it is due as the guys have said.
    Gazza4
    Sep 2009
    suffolk
    thanks for the replys guys , just to make it clear the service book is stamped up to 70k miles with the cambelt and tensioner done on that service , the car has now done 80k miles so there is no way in my opion that after 10k miles it should need replacing ........
    But What they rekon is it might have to be removed to change the manifold which i think is stupid ,
    and i just wanted to check that you can change the manifold without removing the belt
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    yes you can!!!, had a quote from vx for manifold and had no mention of cam belt!, be firm and tell them NO WAY!!.
    Sep 2009
    suffolk
    Well update time ..... They started it this morning at 10 am at 3pm they rang me and said theres no way of doing the job without taking the cambelt off because of the high presure fuel pump ???? , the car still isn't finished after 7 hrs and now I won't get it back till late Monday
    Any opions on it ?
    Jun 2009
    Glasgow
    IV just fitted my new inlet manifold.Hi pressure pump has to come off but pump pulley and cambelt can stay in place.Two bolts hold pulley on to pump bracket!!
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    lad i know just told me i need my manifold done and he has a proper tool so belt doesnt need removed
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    its too late for me they did the same to me i did not know so i paid
  1. Had Inlet Manifold Replaced ..... 1 Question
    By WeDesign in forum Engine & Drivetrain
    Last Post: 14th August 2012, 12:06
  2. Quick Inlet manifold question !
    By ted in forum Engine & Drivetrain
    Last Post: 5th March 2012, 22:35
  3. 150 cdti inlet manifold question
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2011, 20:40
  4. Another cdti inlet manifold question
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 23:43
  5. Inlet manifold/warranty question
    By johnnyboy1985 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 21:35
vauxhall vectra 150 inlet manifold removal
insignia inlet manifold removal
how long to remove inlet manifold on vectra 150
