Thread: map sensor
    south shields
    Default map sensor
    just had codes read came back with map sensor fault, can anyone tell me where it is, so i can check first before i buy
    cheers
    Bristol
    Vehicle : CDTI 150
    Give us a clue, what engine you got?
    For MAP sensor read boost sensor. If your is a diesel read the how to clean CDTI boost sensor thread. It says in there.
    south shields
    engine is 2.0 dti y20dth code fault for map sensor was p0105
    cheers
    Bristol
    Vehicle : CDTI 150
    Ok, remove the engine cover.
    At the front right hand side of the engine you will see a large black hose.
    This joins the inlet manifold. just after the join and between the inlet manifold and head lies the MAP sensor. To remove undo the plug and remove the bolt/torx bolt. The MAP has a small rubber seal around it so is a tight fit just need to gently wiggle it out.
    Should take less than 30 mins to replace from bonnet up to bonnet down.
    south shields
    cheers thanks for that
    Regular Member OSSY's Avatar
    Apr 2009
    I followed this link... easy...
    http://www.vectra-c.com/forum/showthread.php?t=88845
    Good luck...
    Bristol
    Vehicle : CDTI 150
    "I followed this link... easy...
    Good luck..."
    Thats my How 2
    Oct 2010
    Bracknell
    Default AA Clark Limited Bracknell
    AA Clark in Bracknell just tried to charge me £288.05 + VAT to change the MAP Sensor. Took me 20 minutes; oh and the sensor £44.00 + VAT.
    Bristol
    Vehicle : CDTI 150
    Wowwwwwwwwwwwwwww.
    I expect the mechanics dont get £690 an hour, I know they have overheads but that is ridiculous
    Quote Originally Posted by gazzaakki View Post
    thats aa clark for you , what part of bracknell you in , im in great hollands
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
vectra c 2.0dti map sensor fault
