Results 1 to 3 of 3
Thread: sorry another hid question
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default sorry another hid question
    sorry about this guys i've done a search but not found what i'm after. Before i embark on fitting my hid kit from hids direct i.m trying to get prepared cos i'm not good at this sort of thing anyway can anyone tell me how does the actual bulb fit in. Is it like on the vecta b where you have the spring clip to hold it in place or different also does anyone have pictures of the bulbs in place from inside the engine bay. secondly how do you move the washer bottle filler neck as i.ve noticed there aint any space there i want to do it without havibg to remove the bumper . Oh if there.s anyone local to me who has done it on a facelift vectra before and fancies earning some cash i would gladly pay someone to do it for me. This is one of those jobs that although lots of people has said is easy i just don.t fancy making a **** up of. Thanks guys
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The new hid bulb fits exactly like the OE halogen bulb, there is a twist clip that you turn and pull away - if you got new bulb holders in your kit then use those, other wise you will need to seperate the metal clip from the holder to cut a slit in it to fit the hid bulb wires through.
    If the facelift washer neck is like the pre-facelift then it just pulls out, as its held in by a rubber connector.
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Easiest way by far is to drop the front bumper off, seems daunting but can be done in 5 minutes. You can then remove each headlamp to fit the HID kit, you'll also notice a place under the headlamp that fits the ballast perfectly. The bulbs on the facelift just push in and pull out, no need to use the supplied metal clips with the kit.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
