Results 1 to 10 of 18
Thread: twin set up for 1.9 cdti SRI 08
    Jul 2009
    lincoln
    Default twin set up for 1.9 cdti SRI 08
    Hi All
    Where is the best place to get this done - I need a the Y section and the extra right hand side pipe. I live in Lincoln.
    Am I right in thinking that the VXR rear diffuser is cheaper than getting a double exit SRI one. Also, is it a straight swap and fit job.
    Regular Member P3tchy's Avatar
    Milton Keynes
    If you have the SRi rear bumper and use genuine parts then it should all be straight fit.
    2.2 direct setup would go straight on.
    Jul 2009
    lincoln
    Thanks - 2.2 direct, is that a diesel too. Can i get one from stealers - the 2.2 direct ,
    Milton Keynes
    2.2 direct is petrol but apparently the Y piece and O/S box fit the oil burner.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You can get a custom exhaust place to make you up a Y-Piece for cheaper than proper VX\Irmscher.
    Jul 2009
    lincoln
    Thanks - gonna check powerflow
    Oct 2009
    Swindon
    Sri rear bumper panel is much cheaper than SRi item.
    Diesel and petrol back boxes are not the same.....petrol boxes contain baffles, diesels do not, this will effect any escape of gases from the pertol rear box (you won't get anything as gases will take the path of least resistance) would be ok if you used two pertol back boxes but have no idea how that would effect performance. This was confirmed to me by the guy that did my custom exhaust and has also been disscussed here on the forum.
    Jul 2009
    lincoln
    thanks - i appreciate the advice
    Oct 2009
    Swindon
    Oh and I meant VXR is cheaper than SRi bumper insert!
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by damian s View Post
    oh and i meant vxr is cheaper than sri bumper insert!
    VXR Insert £46
  1. twin turbo 1.9 cdti vec
    By paul07design in forum Diesel Engine related
    Last Post: 21st October 2012, 13:34
  2. 1.9 CDTi Twin Exhaust...
    By Penfold101 in forum Styling
    Last Post: 14th March 2012, 21:32
  3. 3.2 gsi twin back box on 1.9 cdti???
    By danny_n in forum Engine & Drivetrain
    Last Post: 23rd June 2011, 08:53
  4. Twin exhausts on 1.9 cdti
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2008, 14:18
  5. Twin Exhausts for 1.9 CDTI SRI 150
    By Rodnoc in forum Styling
    Last Post: 13th November 2006, 23:05
